Old 07-21-2012   #1
vilant
Default Which oil pressure sensor?
My oil pressure gauge is all over from 0-80psi. Looked through solutions and parts list and I'm confused as to which sensor controls the gauge on the instrument panel. Is it AC delco # D1846(single pin), which is located on the right side of engine underneath oil filter by oil cooler hoses? Or is it AC delco # D1808a(three pin), which is located right next to oil filter, accessible from top of engine? Bought the single pin sensor, but now I'm not sure if I bought the right one as the 3-pin sensor looks like it has a coating of oil on it. Any help would be appreciated
Old 07-21-2012   #2
Default Re: Which oil pressure sensor?
gauge runs off the top one
Old 07-21-2012   #3
VetteMed
The gauge receives its input from the larger black cylindrical sensor, mounted upright at the forward / RH edge of the oil filter housing.
The switch which activates the "check gauges" light on the dash cluster, is the shorter black cylindrical switch, low down on the RH side of the oil filter housing.
FYI, the oil temp sender is the third sender/sensor on the housing; this is a brass unit low down on the front of the housing.
Andrew
Old 07-21-2012   #4
scottfab
scottfab's Avatar
http://www.ecklerscorvette.com/corve...1990-1995.html
Scott
Old 07-21-2012   #5
vilant
Thanks, guys. Looks like I'll have a spare sensor, lol. At least the one I need to fix, is alot easier to get to.
Old 07-21-2012   #6
mike100
I need one also. Been putting it off.
Old 07-21-2012   #7
scottfab
scottfab's Avatar
Some years ago my oil pressure sender leaked.
I repaired it and it has not leaked since.
http://www.zr1netregistry.com/ZR1_oilpressure.htm
Scott
Old 07-22-2012   #8
vilant
I repaired it and it had not leaked since.
Thanks. You know I saw your post somewhere before, but then I couldn't find it again. I found the whole assembly on ebay, new with shipping for $26.47
http://www.ebay.com/itm/ACDelco-D180...ef69a1&vxp=mtr
I'll more than likely damage the sensor, but once I replace it w/ a one I'll try to repair the old one, that way I'll have a spare. You should have a free lifetime membership for the amount of useful information you but in here.
Old 07-22-2012   #9
PhillipsLT5
PhillipsLT5's Avatar
http://jerrysgaskets.com/store2/root/
Jerry also has what you need
Replaced all 3 since I had it apart
Old 07-22-2012   #10
vilant
Thanks, but I already bought it from ebay, but I'll buy what I need to repair the old one from Jerry. I searched for the Neihoff DR4010, and nothing came up though. He didn't have AC Delco D1808a either, unless I'm navigating wrong, I used his search for both products and no matches came up.
