Old 03-26-2013   #1
janozr1
Default secondarries
Hi to all ,
Im going to eliminate secondarries with Haibeck prom - got vacum
hadecke with this nassesary sistem....everything will go out
Will cruise control - tempomat , afer that still working?
Thanks fo repy.
Jano
janozr1 is offline   Reply With Quote
Old 03-26-2013   #2
Blue Flame Restorations
Default Re: secondarries
I doubt that you'll ever regret "ripping out" the secondaries.
I'm sure someone will answer your question shortly.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 03-26-2013   #3
Originally Posted by janozr1 View Post
Hi to all ,
Thanks fo repy.
Jano
Yes, cruise control and themperature controls, etc will still work. And, I think you will like the way it runs without them too!
Everything in PINK comes out. As you can see, the vacuum port on the right side of the plenum supplies vacuum for the cruise and everything else.
Unless you have a "kit", you'll need some gaskets and some freeze plugs. I would assume Marc is going to round those up as a package and send it along with the prom, yes? If NO, then be sure to ask him for them, or PM me and we'll get it handled.
Jerry...are you reading this? You know the gaskets he'll need, and also the freeze plugs (Dorman 555s, as I recall?).
P.
Old 03-26-2013   #4
scottfab
scottfab's Avatar
Hi to all ,
Thanks fo repy.
Jano
Good luck with your LT4.9 conversion.
Scott
Old 03-26-2013   #5
Default Re: secondaries
Hi to all ,
Thanks fo repy.
Jano
As Paul says....Cruize Control is still functional as long as you do not eliminate the Cruize Control Vacuum on Passenger Side of Plenum. I think the passenger side Vacuum is Cruize Control and HVAC Vacuum ONLY which I think is what Paul is saying
As you can see, the vacuum port on the right side of the plenum supplies vacuum for the cruise and everything HVAC else.
P.
see # 3 of LT5 Eliminated Systems
See Vacuum Systems (Secondary and Cruize)
Old 03-26-2013   #6
Woops..... Another KLUDGE!
Old 03-26-2013   #7
Fully Vetted
Fully Vetted's Avatar
Let's see. That means our hp per litre actually goes up!
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 03-27-2013   #8
scottfab
scottfab's Avatar
It's not a kludge if it's well documented and supportable. Just a LT4.9
Scott
Old 03-27-2013   #9
Well, I guess this delete secondaries thread is officially complete now!
P.
PS That should be LT5.1 = an improvement in performance and reliability.
Old 03-27-2013   #10
Documented failure
http://www.zr1.net/forum/showthread....mpelling+story
Pull em just saying
