Old 01-11-2014   #1
DarkAngel
DarkAngel's Avatar
Default Bose Amplifier
Hello,
i have problems with my 2 front speaker on my '90 zr1
i don't have any sound from them
ive read that it might be the amplifier and i've ordered some new one from ecklers
ive changed them and had to do some welding because new and old connectivity are different
on old connectivity, the wire are welded directly on the motherboard and on the new it has some "pin" that can be plugged and unplugged
unfortunately after all of this, ive plugged them and i obtain a repetitive "tac tac tac" from them
do you have some idea on how to fix this ?
DarkAngel is offline   Reply With Quote
Old 01-11-2014   #2
Schrade
Default Re: Bose Amplifier
Originally Posted by DarkAngel View Post
Hello,
do i have some idea on how to fix this ?
Are you using 'Google Translate'? Syntax is bad on Google Translate...
Did you check to see if any power / signal is coming to the fronts, BEFORE ordering new stuff?
If there's no power / signal to the fronts, can I have your old [good] ones, when the new ones show from Ecklers?
Old 01-11-2014   #3
DarkAngel
DarkAngel's Avatar
i didn't use google translate
my english is that bad ?
Old 01-11-2014   #4
xlr8nflorida
xlr8nflorida's Avatar
It's probably the unit under the floor on the passengers side.
Call Dr. Don - he will get you all squared away. The years are different on the termination of the wires.
http://www.doctordons.com/
There is probably cheaper but Dr. Don does a fantastic job - 1 year warranty. He has done all the radios in my Vettes. It will sound really good when refurbished.
Old 01-11-2014   #5
Schrade
No - it's not bad English Dark Angel, but 'the Devil is in the details'...
Are you saying that you already put in the new ones from Ecklers?
Did you test the leads to each front speaker? Your multimeter should show a voltage increase as the volume is turned up...
Old 01-11-2014   #6
DarkAngel as stated SCHRADE is right start with the basics make sure power is getting to the speakers/amps. As to your English it's better than my French lol and as SCHRADE stated we just want to make sure no details were lost in the translation.
If that checks out the radio brain behind the passenger seat on your 90 is the next logical suspect as stated by xlr8florida and Dr dons is the best choice for repair. GC
Old 01-11-2014   #7
gbrtng
gbrtng's Avatar
1990 is different from 1991 thru 1996 - it sounds like they shipped the wrong part.
Old 01-12-2014   #8
DarkAngel
DarkAngel's Avatar
when i had the car, the radio didn't work at all and it was the cdm that was not working
i've changed it and only the rear speakers works
the volume of the front speaker was between really low and nothing
but there was some noise; that's why i guess it could be the amplifier
i've ordered this part at ecklers
http://www.ecklerscorvette.com/corve...late-1996.html
how does the part behind the passenger seat look like ?
Old 01-12-2014   #9
cvette98pacecar
Dont forget about the Fade in the head unit. There may not be anything wrong with your speakers at all it may be in the head unit where there is little or no output to the front speakers.
I am about to rip an entire aftermarket stereo system out of my LPE. If you are interested I will give you one heck of a deal on everything.
Old 01-12-2014   #10
scottfab
scottfab's Avatar
Hello,
I would think the place to begin is with a few pictures of the area where you attached the wires. If you take these pictures we maybe able to determine by color of the wires if they are connected correctly.
Do you have a volt/ohm meter of any kind?
Notice this link shows info regarding the wiring on
Scott
