Old 02-26-2014   #1
raymond greene
Default fuel sending unit and pump
I need a new one and I see several on EBay. Delphi for one, for $320 including gasket and strainer. My GM dealer wants $600 plus for one. Ecklers list a separate one for the ZR1. Whats up? Tks
raymond greene is offline   Reply With Quote
Old 02-26-2014   #2
pantera1683
Default Re: fuel sending unit and pump
If you do a search for fuel pumps, you will see an old thread where an updated style Bosch unit is modified a little for use in our cars. I did that three years ago and have been pleased. I don't believe the new pumps came with gaskets though.
Here is the link: http://www.zr1.net/forum/showthread....ght=fuel+pumps
Old 02-26-2014   #3
ScottZ95ZR1
ScottZ95ZR1's Avatar
Buy with confidence from Jerry!
http://jerrysgaskets.com/store2/root...roducts_id=575
ScottZ95ZR1 is offline   Reply With Quote
Old 02-26-2014   #4
efnfast
If Jerry's got it, I'll second that.
Old 02-26-2014   #5
scottfab
scottfab's Avatar
The ones on Rockauto.com are fine for $20 ea.
PERFORMANCE ELECTRIC Part # P240KC
They fit with no cutting the holder.
Just replace both while in there and do NOT ever run the pump in open air. It damages them. Don't ask how I know.
For more info see:
http://www.zr1netregistry.com/Inform...ent-Steps.aspx
and
http://www.zr1netregistry.com/Inform...placement.aspx
Scott
Old 02-26-2014   #6
Look for BB 454 Suburban pumps. They're the same thing. I would try the Bosch units if I needed replacements.
Old 02-27-2014   #7
I and several others had issues with the Airtech units, listed at AutoZone as the replacement for the pump. FYI.
As an aside, at 40k miles I replaced my fuel filter (located on the frame, behind the right front wheel) the same time I replaced my fuel pumps. I was shocked at the amount of crud that was in there!.
Old 02-27-2014   #8
Paul,
Great point! That and the "socks" on the pumps. Sometimes they are plugged to the point where the pump is sucking up the socks impeding the flow of fuel.
Old 02-27-2014   #9
scottfab
scottfab's Avatar
I agree. The strainers should be swapped out too. Most pumps come with one.
Scott
Old 02-27-2014   #10
For more info see:
and
Scott, Are you currently using these or know someone who is without any issues?
