Old 07-21-2014   #1
Schrade
Default Why don't they start right up?
Does any one know with certainty why LT5 doesn't start right up immediately?
Was it the same way on the showroom floor?
This is the first electronically FI car I've owned that didn't do so instantly. Even the first one I owned, an L-98 that was in a poor state of tune when I got it, would start immediately. Foreign, domestic, 4's, 6's, etc.
On RARE occasions, it WILL fire almost instantly. But most of the time, it's 2 - 3 seconds. And I'll let off the starter then, and re-try.
I thought I read once on the boards here that ECM had to see some crankshaft position first, before issuing fire @ the plugs; this would mean, if correct, that it WOULD have exhibited the same behavior at the dealer, when new.
Does anyone know DEFINITIVELY the answer here?
Old 07-21-2014   #2
Default Re: Why don't they start right up?
this is what I've always heard to be the case also.
Old 07-21-2014   #3
BigJohn
BigJohn's Avatar
Never noticed!
Mine starts right up with a good battery.
Old 07-21-2014   #4
QB93Z
QB93Z's Avatar
It could be because the Crankshaft has to rotate until the Ignition Module gets a signal from the Crankshaft Position Sensor so it can determine the correct ignition timing.
Old 07-21-2014   #5
RyanChappel
Smile My lo-mile '91
with new Accel injectors and a good (batt-tender maintained)charge, has to crank a couple seconds to fire...and I'm always thrilled it did...
RyanChappel is offline   Reply With Quote
Old 07-21-2014   #6
This is what I have read also crank needs to make one complete revolution, but it may also have something to do with were the sensor is at shut down.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 07-21-2014   #7
Fully Vetted
Fully Vetted's Avatar
It could just be in my head but I've noticed it seems to fire quicker when I turn on the ignition and wait a couple of secs before engaging the starter.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 07-21-2014   #8
USAZR1
USAZR1's Avatar
I've noticed this,too.
USAZR1 is offline   Reply With Quote
Old 07-21-2014   #9
BigJohn
BigJohn's Avatar
Try starting my 32!
Old 07-21-2014   #10
Fully Vetted
My Dad's '31 Model A starts so fast we had a standing challenge: If you can engage the starter at all and it not start he would buy dinner.
He never bought dinner....
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
