I would like some input from anybody using the Flowmaster catback system #17115. What can you tell me about it? Sound, performance, ease of installation. How did it perform as a bolt on mod, i.e. no aftermarket chip. Thanks for any info you all mght be able to provide me.
![]() Join Date: Apr 2004
Love mine…good fit easy install, great sound with no resonance
#3 | |
![]() Join Date: Oct 2004
http://www.corvetteactioncenter.com/....php?qstId=534 I have heard his car...sounds nice. Uly |
That Hib article is about a custom system. It looks like he only used the resonator from the Flowmaster cat-back system. One thing I found frustrating about his article was all the custom work done to fit that resonator into the LT4 system, yet there isn't a single picture that shows it!
FWIW, you can get the Flowmaster system from Summitracing for under $600 new. Also, FWIW, if you were going to have a shop install it, you could probably just have a shop replace your mufflers with Flowmaster mufflers. If you had a '93-95 then it would probably have a similar or better gain, plus you could keep the stock look with the rectangle tip. But if you want to do it yourself or you want to keep the stock system in-tact, or whatever, the Flowmaster is certainly a low-cost cat-back way to go. I seem to recall reading on the listserv archives about the resonator not being very ideal inside, though I can't recall exactly. Flowmaster generally has a very nice sound, though. ![]() |
#5 | |
Thanks |
Just did the cat back..I also have an open air cleaner & K&N no other mods..I do have one of Marks chips but took it back out as I was getting to much ping. I had old blue dynoed bone stock a few years back at 18K miles and put down 326rwhp. I painted the pipes and muffs flat black.
I've been told you will gain 10 to 12 rwhp from a good cat back system. I can tell a bit of improvment in 1st and 2nd more wheel spin ![]() I hope to get a good dyno tune next summer using Mark's chip I think it just needs the timming reset. |
#7 | |
![]() Join Date: Jun 2005
[quote=Aurora40]That Hib article is about a custom system. It looks like he only used the resonator from the Flowmaster cat-back system. One thing I found frustrating about his article was all the custom work done to fit that resonator into the LT4 system, yet there isn't a single picture that shows it!
(snip) That's a legitimate complaint and I apologize for that shortcoming. The web-based version of that article was based in-part on an earlier print version of the story and there were some diffculties during the creation of the web version such that some pictures were lost. I should add that adding the Flowmaster resonator to the stock LT5 head pipes then adding the LT4 rear section to that, while a time consuming job, is a task that any exhaust fabricator should be able to handle....an everyday, low-cost "muffler shop", maybe not...but a facility which has good welding skills and equipment and does high-end exhaust work should be able to handle it. Quote:
Converting from stock to a Flowmaster cat-back on a stock or near-stock ZR-1 gains between 8 and 12 hp.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 12-14-2006 at 10:04 AM. |
#8 | ||
I'm making an assumption, and it may not be the right one. I figured if someone was going for the Flowmaster system, they probably wanted a good sound and a good price, not necessarily the most HP increase. Which is why I suggested doing just the mufflers. It would probably be a fair bit cheaper, especially if you would have paid a shop to install the cat-back system. And I suspect it would have that Flowmaster sound, and be fairly similar in the power change. The muffler-inlet restriction shouldn't be an issue. The pipe could be cut past the taper, and/or flared out to whatever the diameter of the replacement muffler is. I think the 40 and 50 series can be had in 2.5 or 3" diameters in a case similar in size to stock. |
#9 | |||
snip
The Flowmaster resonator, is single in and two out. We modified it to accept a larger inlet. Quote:
#10 |
![]() Join Date: Jan 2006
John,
I did a similar experiment back in 2003 as Hib. I used a Magnaflow 2 1/2 inch x-pipe and the Magnaflow Corvette C4 3 inch mufflers. I wanted a 3 inch x-pipe but they did not make it at the time. I talked with Magnaflow and got them (or got on the bandwagon) to produce a 3 inch x-pipe and put it in later. I did not dyno the 3 inch x-pipe but felt the car lost some low end. Here is the result of six pulls each: 1) stock car 2) stock car until the cats then a 3 inch piped system with a 2 1/2 inch x-pipe and 3 inch mufflers. ![]() The resonance was tough. Slightly worse than a B&B with x-pipe. Ted |
