Old 06-04-2020   #1
Scrrem
Scrrem's Avatar
Default WTB: Corsa H-Pipe
Looking for a Corsa H-Pipe and resonator assembly.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 06-04-2020   #2
Default Re: WTB: Corsa H-Pipe
why just the resonator/H pipe?
Old 06-04-2020   #3
Scrrem
Scrrem's Avatar
I had it on the lift over the weekend and found that the welds around both pipes at the front are cracked almost all the way around. It's like the resonator is breaking away from the two pipes. I was hoping someone that converted to and X pipe had one laying around. If I can't find one, I may be putting on a new system or upgrading the 3" and install those power effects mufflers.
Rich
Ron Davis Radiator
Old 06-04-2020   #4
Rich
You do know that Dr. Phil has a new toy. Right?
Old 06-05-2020   #5
Scrrem
Scrrem's Avatar
Yeah, I'm just not sure if you can get into that area to weld or not and you probably can't get into the space to clean it up (prep metal) to weld. I'll shoot some pictures, you'll see what I mean.
Ron Davis Radiator
Old 06-05-2020   #6
dredgeguy
dredgeguy's Avatar
Sounds like a good reason for a informal get together this weekend!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 06-05-2020   #7
Scrrem
Scrrem's Avatar
Hey no Covet-19 here....come on down.
Rich
Ron Davis Radiator
Old 06-05-2020   #8
dredgeguy
dredgeguy's Avatar
Perfect, having withdrawls here
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 06-05-2020   #9
Scrrem
Scrrem's Avatar
So you thinking Sat....Sun? I can do either, not much going on here.
Ron Davis Radiator
Old 06-05-2020   #10
dredgeguy
dredgeguy's Avatar
Check with the brothers, I am open and it looks to be mostly dry both days
Charlie
__________
Dredgeguy
Dana 4:10 gears
