Old 05-23-2020   #1
Bradjon
Default Wel the car just died while driving on the freeway
Driving home from bills car started running a little rough and the fuel mileage I was getting worse by the minute so pulled into wrest stop and everything seemed ok and poof she just died Turns over won’t start coed tps and map and the 2 cool a connections all ok anyone have a idea what’s wrong starter spins good so ain’t low battery he’ll p please
Bradjon is offline   Reply With Quote
Old 05-23-2020   #2
Bradjon
Default Re: Wel the car just died while driving on the freeway
Have done a little caking while waiting for a tow inj 2 10 amp fuse blew tried another and same thing what caused that fuse to blow ?
Old 05-24-2020   #3
RussMcB
A shorted wire somewhere?
Old 05-24-2020   #4
Ccmano
If you recently had the plenum off, check the wires from the injectors. I’ve seen them get pinched and short out when the plenum is reinstalled causing inj1 or inj2 to blow. Typically at the corners of the plenum. Good luck.
H
Ccmano is online now   Reply With Quote
Old 05-24-2020   #5
Bradjon
Well here’s the wired Paul Harvey . Bill had just fixed my windshield wipers a wire came off well I sorted home 80 miles out car just died . Get towed back to bill we put pumps in her and nada . We are going nuts testing everything when bill say for giggles let’s pull this wire off the wipers and hehe she starts wtf ??????electrics I hunk will always drive me nuts
Old 05-24-2020   #6
Ccmano
If that’s the case you’ve got a wiring problem elsewhere. That needs to be tracked down otherwise this will happen again.
H
