Old 01-18-2011   #1
Toyvet1
Default Productive week...
Have had a good couple weekends. I was able to lower the front end with the wedge kit.Rear will be done in the future. Cut the rotors and installed Hawk pads, cleaned the suspension.
I have a vacuum leak somewhere and I have oil leak at the breather cover. So Im replacing the breather gaskets . the IH gaskets and resealing everthing . What a mess under there.
-=jeff=- was a big help getting the new Dymags to the stripper so they can be powdercoated. Next up is figuring out if Im going GY or Kuhmo's.
Then the last project is a set of seats out of a newer model....
Then I can start on the 79......
Old 01-18-2011   #2
Pete
Pete's Avatar
Default Re: Productive week...
Hey Ken
Are the 94/95 seats lighter then the earlier seats.
Anybody know?
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-18-2011   #3
Hey Jim
Anybody know?
Pete
What does the OEM 90-93 Sport seat weigh? If/when I remove one I will weigh it, I do have a 94-96 base seat assembled to get a close weight from
Old 01-18-2011   #4
thought you were leaving the PC alone?
Old 01-18-2011   #5
Pete
Pete's Avatar
I know what the 1991 seats weigh about 45lbs with track.
Jeff weigh the new seats let me know what they weigh.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-19-2011   #6
will do in the next couple of days.. when I have a chance
Old 01-19-2011   #7
Hey Jim
Anybody know?
Pete
Well, the standard 95s ARE lighter than the 90 sport seats - sans motors and switches, etc. - maybe 3-4# ea.? Some weight can be removed, I suppose, if the electric tracks were replaced with the manual adjusted type. Or, since you are the only driver you could replace the track with aluminum square tubing and drill holes in them to mount the seats to fit you.
And, now that I think about it some sort of a track could be fabricated out of aluminum, if you want to make a significant reduction in the seat/track combo....Just a thought.
P.
Old 01-19-2011   #8
Toyvet1
Lee, last week when I looked at the wheels close I changed my mind. Chris didnt remove hardely and of the PC from the barrels. And there was media material under the PC. So before i go through the effort to mount tire I decided to redo them and go with a lighter color. More of a pewter in place of ther graphite on them now.
Old 01-19-2011   #9
Q: Did you turn the rotors in effort to just clean them up for the new pads, or was there a hard spot one one (or more) of them; the infamous "warped rotor" syndrome?
P.
Old 01-19-2011   #10
VetteMed
Having recently swapped '91 seats for '96 seats, the later seats are definitely a few pounds lighter.
