Old 10-19-2012   #1
Corbusa
Default help me help me !!!!!
Guys I went to get out the vette ( 1990) and I opened the door and it automatically locked( I thought thats weird ) I didnt think I pushed anything. I closed the door and the alarm went off, I jumped in and inserted the key( I figured it would read the chip and reset) , Nope .. It wont start / nada.. The aftermarket alarm is roaring as well( which I can shut off. what or how do I reset everything? Thanks Ohh after a minute or so the alarm shut off.. still no start.
Old 10-19-2012   #2
Corbusa
Default Re: help me help me !!!!!
Every time I open the doors it sounds off. aaaaaaaaaaaaaaaaah ! its inside the garage at least . But sure hurts the ears.
Old 10-19-2012   #3
Did you the key in the ignition? (On position)
You locked and unlocked the driver door? (That should disable the aftermarket alarm)
What aftermarket alarm do you have?
Could be a vats issue too, if so wait 30 min before turning the ignition
Old 10-19-2012   #4
Corbusa
yes I put the key in and tried to start it , It did nothing.. I have a clifford alarm ( aftermarket) I can shut it off
now that I think about it my stereo has a light flashing too .
I'd sure like to know the cause , BEcause it be a B to go for a drive and have it do this.. Thanks I'll wait a 1/2 hour and see what happens..
Old 10-19-2012   #5
RyanChappel
Default Spooky!!!
When is Halloween in Tennessee????
RyanChappel is offline   Reply With Quote
Old 10-19-2012   #6
Corbusa
shhezzzzzzzzz Funny Its Dec 26th
Old 10-19-2012   #7
Did it start?
Old 10-19-2012   #8
Corbusa
No !! every time I open the door it starts honking the horn.. Esp inside I had to go get earmuffs .. I know the neighbors are tired of it after a minute it shuts off and if I push the door unlock button on the alarm system It sets the alarm off again and no start. I may just disconnect the horns for now..
Old 10-19-2012   #9
A1990
A1990's Avatar
have you locked and unlocked your drivers side door with the key?
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 10-19-2012   #10
Pete
Pete's Avatar
Stick the door key in the door key hole and lock and unlock the door with the key.
That's how you shut down the OE alarm.
The factory alarm needs to see the after market alarm.
If your aftermarket alarm has an output momentary ground (-) you need to connect that to your green wire coming from the door key lock/unlock cylinder,needs to see a momentary ground so it thinks you stuck the key in the door key hole.
You can find the green wire from the bundle of wires coming thru the door to inside under the dash panel drivers side the way to make sure you have the correct wie get your test light put it to hot (+) and the other check the wire and cycle the door lock key light should light up everytime you cycle/unluck the key.
Usually aftermarket alarms should have a dome light output just make sure it's a ground (-)output.
If you need more info let me know.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
