Old 04-10-2013   #1
oricale
Default Had a quick question about choking on deceleration.
I think I fixed the smoking issue(for the most part and did a few other things for this season)..BUT
I have always had this issue:....Upon releasing the gas pedel and allowing the car to slow itself by the gear with no brake on..and after a bit of deceleration at high rpm's its starts to choke on itself and sputter..all this goes away with a minimal amount of gas pedal.
Any ideas??
oricale is offline   Reply With Quote
Old 04-10-2013   #2
scottfab
scottfab's Avatar
Default Re: Had a quick question about choking on deceleration.
TB plates or IAC sticking.
Scott
Old 04-10-2013   #3
oricale
Actually I dont think the IAC functions correctly...a whileago we disconnected it and nothing happenend!...hmmmm
Old 04-10-2013   #4
Choking? What does at mean? Shutting off? Does it happen at a particular mph?
Old 04-10-2013   #5
oricale
Choking like it cant breath or not getting gas maybe.
not sure of mph...its usually after about 3-5 seconds of deceleration
Old 04-10-2013   #6
Hib Halverson
If you unplug the IAC while the engine's running, it will hold its setting which might seem like nothing happened, at least for a short while.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 04-10-2013   #7
oricale
OK Hib, pull it while its running and leave it off longer?
before when I had a smoke issue, the idle would fluctuate, currently is rock steady at 950 rpm.I thought that was a indication of a nad IAC.
Old 04-11-2013   #8
Fully Vetted
Fully Vetted's Avatar
What was the smoke issue?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 04-11-2013   #9
What mods on the motor to have a 950rpm idle?
Old 04-11-2013   #10
If you have a GM EPROM (?) then the program has DFCO, it's a fuel cut off under compression braking. Could this be what you are feeling? I forget at what rpm it comes "in", but it's closer to idle speed than not, say about 1100 or maybe less....I don't notice it any longer as I guess I'm used to it now. When I first got the car I noticed it right away. Just a thought.
