Old 05-11-2014   #1
Karl
Karl's Avatar
Default testing the ALCL. poor cold start running
What are the pins and their location on the ALCL to test for trouble codes? I am referring to the paper clip method. If I remember correctly they are the slots in the upper right corner but I am may be wrong.
I started my z yesterday and not more than 100 feet later the car began to stumble and almost cut off. After warming up it went away and began to drive fine except for a slight bog in 2nd gear under load.
The car has about 68K on the clock and there seem to be a lot of original parts on the car. I have replaced the coils and wires. The prior owner installed new FIC injectors that are ethanol compliant.
Thanks ahead of time!
Old 05-11-2014   #2
Default Re: testing the ALCL. poor cold start running
Did you get a Set light? If not, you may not see any codes
Old 05-11-2014   #3
Karl
Karl's Avatar
No SES light.
Old 05-11-2014   #4
Roadster
Roadster's Avatar
That's where they are on my 82, and I would imagine that they are the same for our Z's....
Not being too familiar with the LT5, I would assume that you start from the beginning. Such as, fuel delivery, spark (ignition), grounds, etc.,etc. If the engine doesn't have a code, you would need to go through each system to narrow down the source of the problem....JMO
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-11-2014   #5
The ZR-1 is an OBD-1 car. Pins and pulling codes is the same across all vehicles.
Old 05-11-2014   #6
Karl
Karl's Avatar
I assume they are the top two right pin holes, pin A & B?
FEDCBA
G
Old 05-11-2014   #7
Karl
Karl's Avatar
Never mind, I just tested the ALCL and it threw no codes.
Old 05-12-2014   #8
Karl
Karl's Avatar
I am beginning to think I may have a fuel problem
Is there anything specific about the ZR-1 fuel system any care to share?
In particular how the fuel pumps work?
I just connected a fuel pressure gauge and it would not move past 20 psi at idle and it bounced maybe to 25 psi while driving the car.
I think either my fuel filter is clogged or the problem lies within the fuel pumps and or assembly.
I put the gauge on my daily driver Malibu and it held 30 psi so I know the gauge is working.
Is this normal fuel pressure for the LT-5?
Old 05-12-2014   #9
Karl,
The FP should be in the 43+# range. If you haven't changed the filter, you should do it anyway. You may want to check the pumps. If they are original, it can also be an issue w the plastic clamps in the tank. They may be loose enough so that they lose pressure sort of like a leaky blood vessel. If not that, could be time to change the pumps
Old 05-12-2014   #10
Franke
Karl,
What XfireZ51 said plus I am surprised that it runs with that low of a fuel pressure. Interesting.
