Old 01-31-2007   #1
Jerry#397
Jerry#397's Avatar
Default Torsion Dampener Pictures
Attached are the pictures of the Torsion Dampener that was replaced on my 93 ZR1 recently and described in a e-mail on the net.
Thanks,
Jerry 93 White ZR1 #397
Jerry#397 is offline   Reply With Quote
Old 01-31-2007   #2
jonszr1
jonszr1's Avatar
Default Re: Torsion Dampener Pictures
how did it happen .did the rubber rot out? what did the motor do ? just curious
Old 01-31-2007   #3
Jerry#397
Jerry#397's Avatar
John,
The car has 79000 miles, my belief is that the rubber got brittle and cracked, then the piece fell out. The engine had a slight vibration, I could tell something was not right, howver, those riding in the car could feel or hear nothing. You'll need a mirror to check it out, it's very difficult to see and I would not have found it. As I said in my Net e-mail the shop I took it to found it while inspecting the car. It is a PTA to change out.
Thanks,
Jerry
Old 01-31-2007   #4
Jeffvette
Jerry, one thing to consider as well is the use of chemicals to clean around the engine compartment.
I never got the pics from you.
Old 02-01-2007   #5
95ZR1#418
95ZR1#418's Avatar
Your right Jeff, I've dropped allot of LSD & Cocain down there while showing the mighty LT5 to people and my dampener rotted off at the crank!
95ZR1#418 is offline   Reply With Quote
Old 02-01-2007   #6
Jerry#397
Jerry#397's Avatar
Jeff,
Check your e-mail, if you didn't get the pic's or my latest e-mail to you concerning a Ron Davis Rad. then I have the wrong e-mail address for you; are you still at yahoo?
Thanks,
Jerry
