Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Detailing, Cleaning, and Waxing
Old 08-20-2013   #1
Racinfan83
Default Getting Overspray Off?
Thoroughly cleaned and waxed the car yesterday, getting ready for two shows this weekend. It has some white paint overspray on the hood and front bumper. You can get some off with a fingernail, but that leaves fine scratches in an otherwise mirror finish. Stuff does not rub off easily at all. I don't have a buffer or anything like that. Don't want to mess up the mirror finish I have - but the white overspray on black paint bugs the heck outta me. Ideas?
Old 08-20-2013   #2
Default Re: Getting Overspray Off?
clay bar
Old 08-20-2013   #3
Originally Posted by Kevin View Post
clay bar
X 2
Old 08-20-2013   #4
Racinfan83
Ok thanks!!! I never tried one of those - but was wondering if it would work....
Old 08-20-2013   #5
oricale
Cool Re: Getting Overspray Off?
X3.....I had a ton of red overspray on my white '91 and I clay bar'd and waxed the while car..worked great!..
oricale is offline   Reply With Quote
Old 08-21-2013   #6
Racinfan83
Well I picked up a Meguiars Clay bar kit on the way home today and tried it out. Got a lot of the spots off. Not all - but most. Considering I had never used a clay bar before - and really had no clue what to do with it other then reading the directions on the box - not too bad. I'm thinkin I kinda screwed myself when I waxed over the overspray with poly wax on Monday.
I used the spray detailer that came in the kit for lube. Is the clay supposed to move freely over the surface like on ice (super wet) - or should it be a bit "sticky" in order to work the best? It got NO black residue on the clay - so I assume the finish is really good - or did I do something wrong? I only did the hood where the worst of it was - after all the cleaning/waxing I've done the last week my hands and arms are SHOT...
Any hints for next time would be appreciated....
Old 08-21-2013   #7
super wet, if it's stickey it's grabbing the paint and will mar it. i can try to find a detailer around you area if you tell us where you live
Old 08-22-2013   #8
Racinfan83
I live in St Charles County, about 25 miles West of St Louis, Mo. Zip here is 63376. Thanks!
Old 08-22-2013   #9
Wash the car well with dish soap.....yes Dawn etc. Leave the car wet. With another bucket of very soapy water clay bar the overspray area's clean. You will know when all the overspray etc. are out. The clay bar will glide easily across the paint. Wash again with car wash soap dry and then start your wax regimen. It's an easy process really. Don't worry you won't screw up anything. Just make sure the clay bar is lubed well.
Old 08-22-2013   #10
randy ransome
randy ransome's Avatar
This my sound unbelievable but you can also use lacquer thinner on a rag.
It won't hurt factory paint as long as you just wipe then clean it off.
I've used it hundreds of times.
