![]() Join Date: Dec 2005
Does anyone know the GM part number, availability or a source for the black 4 wire electrical connector to the right side of the throttle body? I believe this is the throttle position sensor.
I learned the lock on the side is very brittle when cold, need a new one. ![]() Thanks in advance.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
![]() Join Date: Feb 2006
very brittle when old too.
![]() Join Date: Sep 2005
Since he said 4 wire on the right side, I think he is talking about the idle air control?
#4 | |
![]() Looks to be Delco PT757 or GM 12126487 Think I found one.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) Last edited by jrd1990zr1; 03-21-2015 at 04:03 PM. |
![]() Join Date: Oct 2004
That should be correct for the IAC. It does appear to be NLA from GM/ACD but I'd think it's on shelves at many dealers. There should be replacing part numbers that might be less expensive. You mention "finding one" so you should be all set.
