Old 04-09-2012   #1
cvette98pacecar
Default SLP cold air intake.
Has there been any studies on the SLP cold air intake? Is it worth $300.00
Old 04-09-2012   #2
Blue Flame Restorations
Default Re: SLP cold air intake.
I've got one I'll sell you after I get my stainless air box.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-09-2012   #3
cvette98pacecar
I have one of the stainless coming for the Purple car, this is for the Ruby car.
Old 04-09-2012   #4
As I recall, the total surface area of the three cone filters was a little more than the stock or even the flat K&N. Theoretically, that would be advantageous, I suppose. But, sorry...No data for comparison.
P.
Old 04-09-2012   #5
PhillipsLT5
PhillipsLT5's Avatar
Locobob did a comparison, looked like 1 to 3 hp gain with the claw if I remember correctly
Old 04-10-2012   #6
Locobob
Here is the old post from the CF. Results for peak HP were within margin of error but notice the average HP and Torque numbers show a small gain.
Today myself and forum member/dyno owner TJ Wong set out to find the truth regarding C4 air intakes. We dyno tested 3 different air intakes on my Lingenfelter 368cid LT5. Tested today were: stock with paper element, stock with K&N element and a cut lid, and finally SLP's "claw" tri-cone filter design. All dyno pulls were made with starting coolant temps at 195 degrees F. Here are the results.
Stock with paper, two identical pulls: 477rwhp. Avg. peak HP 477
Stock with K&N and cut lid, three pulls: 471, 475, 480rwhp. Avg. peak HP 475.3
SLP tri-cone "claw", three pulls: 477, 478, 481rwhp. Avg. peak HP 478.7
It would appear that the naysayers are mostly correct about C4 air intakes, not much to be gained here. Both Tom and I were rather suprised with the results. We had expected to see some small but visible gains with the cut-lid and SLP, instead we got a bunch of tests with peak numbers being basically the same or well within normal dyno pull to pull variation. The SLP unit does seem to have a small advantage over the others but suprisingly it's in mid range power not peak (see dyno graph average power #'s).
Robert
Old 03-29-2016   #7
Johnny5
Figures. The stock intake is already a cold air intake. Waste of $$$$ for SLP although it looks cool
Johnny5 is offline   Reply With Quote
Old 03-29-2016   #8
KFoster
I have the SLP. Came on the car. I like it, but no flow numbers on it or comparison to anything else. I prefer conical filters to flat myself, but usually use them on blown applications.
1990 ZR1, 1987 Mustang GT (since new), 1973 DeTomaso Pantera, 1987 928S4
Passed on: 1984 930S (gray market), 1988 Mustang Coupe Trooper car(drag)
KFoster is offline   Reply With Quote
Old 03-29-2016   #9
ghlkal
ghlkal's Avatar
Mine had the claw on it when I bought it. I doubt I would pay $300 for it based on performance, but it does look cool.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 03-30-2016   #10
Bob,
It would be interesting to see if anything changes regarding the AFR with these.
