Old 06-01-2016   #1
tchrislip
Default Indicator lights under heater/ac controls
The indicator light below the various functions, off, auto, etc, has begun to blink at times. In addition it will occasionally overheat while in traffic which it has never done before. Any ideas?
tchrislip is offline   Reply With Quote
Old 06-01-2016   #2
Default Re: Indicator lights under heater/ac controls
http://www.zr1.net/forum/showthread.php?p=144455
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-01-2016   #3
Prob a Freon leak. The above link can walk you through the troubleshooting codes
Old 06-02-2016   #4
tchrislip
Thanks. Not flashing now so no faults indicated. I'll check it the next time it does it.
Old 06-02-2016   #5
If your overheating you are still having a problem. I would check the rad cap and R&R the radiator. You prob have a lot of derbries, sand and silt blocking the cooling fins. All C4s are nose air feeders and suck up plastic bags, leaves etc over the years. A little radiator maintenance goes a long way. GC
Old 06-02-2016   #6
tchrislip
Thanks, I'll do that.
