![]() Join Date: Dec 2005
Does anyone know how to test a power switch out of the car? There are three pins, I have a complete circuit thru the common pin and one leg with the key on. The other side appears to be open.
Thanks for the advice
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
As you can see on the schematic only 2 pins on the Valet/Power Key Switch are used.
When the switch is in Full Power Mode, the Dark Blue/White wire is connected thru the switch to ground. ![]() |
I just had mine re-wired to always have the power on... is what the ZR1 craves!
#4 | |
Thank you
