Old 12-16-2016   #1
SAM/CH ZR-1
Default Valve length
Hello guys
I've got a question. Why do the 93-95 models have a shorter valve length in comparison to the 90-92 MY (4.04" vs 4.06")? Is there a special reason behind?
Sam
DR.Z/LT5-Performance
1990 #1822 with 383 cui
SAM/CH ZR-1 is offline   Reply With Quote
Old 12-16-2016   #2
Default Re: Valve length
Yes, lifter compression spec was revised to place lifter plunger travel closer to mid range.
Old 12-17-2016   #3
SAM/CH ZR-1
Thank you Jerry.
So it means when you use for example regrounded stage 2 cams in 93-95 engines you can run into the problem to get not enough lifter pre-load.
Sam
Old 12-17-2016   #4
Originally Posted by SAM/CH ZR-1 View Post
Thank you Jerry.
That is exactly what happens. Depending on how radical the regrind is, even more material is removed from the base circle diameter, and even early/longer valves are not tall enough & lash caps are needed.
Old 12-17-2016   #5
Jagdpanzer
Jagdpanzer's Avatar
The valves I have from two sets of later style heads all the intakes measure 4.018"+- however, the exhaust valves from one set measure 4.057"+-and the other set 4.070"+-
The extra length appears to be above the stem retainer groove.
How do the valves from earlier heads measure?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-17-2016   #6
SAM/CH ZR-1
I measured by a 1990 head the with stock cams and lifters the lifter pre-load and got 0.097". With stage 1 cams the pre-load drop to 0.051"and with stage 2 to 0.025". To make the lifters work properly a minimum pre-load of 0.040-0.070" is required otherwise you can loose valve opening duration and get a noisy valve train. The situation become worse with the shorter 93-95 MY valves.
Sam
Old 12-17-2016   #7
I measured 107 90~92 Exhaust Valves awhile back. Overall height is 4.070 +- 0.003".
I have only had a few new late style valves, so never measured enough to get a good number.
It looks like the 4.057" valves were probably correct late style for the head, but the 4.070" were most likely early length installed in late style heads. Kind off like the carry over early transmission into some of the 1993 cars.
I came to the same conclusion that the difference is above the retainer key groove.
Old 12-17-2016   #8
Your experience with the different cams sounds right with my thinking too. If you're going to get real nit-picky, the exhaust valve stem height should be set about 0.010" less lifter compression to account for thermal growth.
Total lifter travel is pretty darn close to 0.124". Setting stem height to pre-load or compress the lifter, right in the middle of the travel range @ 0.062" will work well for both intake & exhaust valves.
