![]() Join Date: Jan 2005
OK where do i get one of these......does the local auto parts store have them?
![]() Join Date: Nov 2007
Check with Jerry @ Jerry's Gaskets.com is where I'd look first!
![]() Join Date: Sep 2016
AC Delco 214-358. Amazon or Rock Auto. I am waiting on one from Amazon right now to install this weekend. You do have to cut a spline out of the connector port and swap the bracket. The originals are no longer available.
There are 2 types of the solenoid valves,the early type takes a small square foam filter and the later design takes a cylinder type filter. Does anybody know what type of filter this 214-358 takes,looks like the early design.
Maybe four Solenoid Valves?
Vacuum Solenoid for early (90' under Plenum). Vacuum Solenoid (filter) for Later (95' under Plenum)................Solenoid for Charcoal Canister (91'-95' under Plenum). ![]() ![]() Solenoid located on Charcoal Canister (not shown) under Drivers Headlight (90').
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-05-2019 at 06:26 PM. |
214-358 has the square thin filter. The spring steel filter cover snaps on to either the early or late LT5 bracket. Easy peasy. I am doing a 93 MY right now. Test your replacement solenoid before install. I had a bad one that the plastic was malformed inside the nipples.
Thanks guys!!
The filter for the switch is $13.00. This is for a piece of foam that is maybe 1/8 in thick and is 5/8 by 3/4 of an inch. When I went to the dealer to buy the cylinder shaped filter the parts guy ordered this one instead. I thought it was so absurd to charge $13.00 for such a small piece of foam I paid for it and kept it,shows how smart I am.
Just wondering......the OEM part has 3 vacuum ports and the replacement has 3 ports.....how do you make it work?
#10 |
