Old 08-31-2023   #1
aafc
aafc's Avatar
Default LT5 engine spec trim plate
I just got this back from a print shop showing my LT5 engine specs on my
ash tray lid.
Old 08-31-2023   #2
mcich7781
mcich7781's Avatar
Default Re: LT5 engine spec trim plate
I got to have one. How do I go about?
Sent from my SM-A546U using ZR-1 Net Registry mobile app
mcich7781 is offline   Reply With Quote
Old 08-31-2023   #3
aafc
aafc's Avatar
Well first you have to one or fine one. they come up for sale once in awhile.
almost any print shop can make a delcal over the stock lettering.
as you can see mine is a little worn.
350 cubic inches
375 horse power
370 torque ft. lbs
11.1 comp ratio
Hope you can fine one, or take a picture of the label and add your own
information, they may able to duplicate the orginial LT5 emblem.
JOHN
Old 08-31-2023   #4
mcich7781
mcich7781's Avatar
I have one on my cup holder cover. I might just take the whole thing into a sign shop. I will bring my Dyno Sheet to get my specs. I would also want to cover the 5.7 liter. I always refer to my 368 as a 6.0 liter. Thanks for pointing me in the right direction.
Old 08-31-2023   #5
aafc
aafc's Avatar
You know I forgot about the 5.7 liter. 368 convertered to liters is 6.03 liter.
mabe they can make a small delcal that says 6.0 liter. over the 5.7 numbers.
I should think more about what I do and plan ahead! Ill let you know how I
make out.
JOHN
Old 09-01-2023   #6
aafc
aafc's Avatar
Went back to print shop and he said he could change 5.7 to 6.0 decal. He
also said that if you can get a full size photo of the LT5 engine spec trim
piece any print shop could make a same size decal with your engine specs.
I know of a few Corvette sites sell the one for LT1 specs,same size as the LT5
piece.
JOHN
Old 09-01-2023   #7
aafc
aafc's Avatar
I went to Corvette central site and they have engine specs trim plaques for
the LT4 and L98 ,you could use that to make your custom LT5 engine specs.
Then take it to a print shop and have them make it the away you want.
Hope this helps
JOHN
Old 09-01-2023   #8
HAWAIIZR-1's Avatar
If anyone is on Facebook, this guy sells a version that you can customize to order.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
