i ordered a set of rear spring bolts from ecklers, just got them last week and installed them this weekend.......not good! the bolts are listed as having a 3.5 inch adjustment. well it must be all upwards the 3.5,i was looking at droping the azz about an inch or so. i dont know if something was off or what but that thing looked like it was 4-wheel drive
![]() Join Date: May 2005
Lowering bolts should be around 10" long (give or take). If they do not have a hole cross drilled in the last 1/4" or so I recommend that you do this & use a cotter pin. Altho some of the kits provide a nylock nut, these can work loose ... not a pretty sight if you happen to be in triple digits.
Assuming everything went OK with the install the rear end should settle down after driving a couple of miles. It would be wise to get the car aligned at that time, unless you intend to lower the front in the near future. Lowering the front will keep the proper "rake" of the car and greatly improve track handling ... but the job is a bit more involved than lowering the back. I lowered the back (both sides) in less than an hour ... the front took me most of 2 days. Hope this helps. George |
#3 | |
If the bushings are bounding it won't let the suspension settle. Sometimes if other suspension work was done and the mechanic tightened the link bolts with the suspension hanging down it can cause the car ride too high. What are you after? Look or handling? What car is it? Later cars ride higher, softer springs... |
![]() Join Date: Aug 2005
