Old 12-01-2020   #1
jaykran
Default Oem windshield
Is this a oem windshield for 1992?
I don't know if the pic is visible but it says
Sunshade
Solargreen
PPG Duplate
Laminated
Safety float
AS1 41
71
Dot 18 M405
Dw1112
Sent from my SM-G988W using ZR-1 Net Registry mobile app
jaykran is offline   Reply With Quote
Old 12-01-2020   #2
Default Re: Oem windshield
What year is your Z?
If 90 - 93 (I?m guessing) there should be roughly 3? high and 4? wide clear area slightly overlapping defroster grille in the center of the dash. If later years, similar clear area of same height but reduced width around 3?.
If you don?t see clear ?radar detector port?, it?s non-ZR1, standard C4 windshield.
Old 12-01-2020   #3
BTW - if you see question marks, these are either double apostrohies or single apostrophe.
Old 12-01-2020   #4
http://www.zr1.net/forum/showthread.php?p=252874
LOF was the original windshield supplier.
