Old 06-28-2022   #1
Erik
Default Plan. B if I can't get Amsoil Z-Rod?
My car will be going in for some servicing the first of next week, and I don't think I'll be get Z-Rod by then.
I was looking for the High Mileage Mobil 1 at the local Wal-Mart, and all they had was 0-20 and 5-30.
Being in Canada, some of the smaller brands that can be bought in the US aren't easily available up here.
Any plan B recommendations? Oils that would do lesser harm?
Or am I overthinking it and any quality synthetic of appropriate weight would work ok for the time being.
1990 ZR-1 # 996
Old 06-28-2022   #2
Default Re: Plan. B if I can't get Amsoil Z-Rod?
Before I switched to Amsoil and after Mobil quietly reduced Zn and Phosphate level, I ran standard Mobil 1 10w 30 and added a half a bottle of ZDDP. Of course, no way of knowing if it helped or not was impossible. Nonetheless, put my mind at ease?
Old 06-29-2022   #3
Matt B
Matt B's Avatar
Find out if you can get this one https://products.liqui-moly.com/oils...-10w-40-1.html
I think it's sold in Canada.
It's a top notch German producer (actually not just the brand is German but it's MADE here) and that juice is optimized for engines that require a good chunk of heavy duty lubrication - as ours do.
No voodoo, just science
I use Liqui Moly on all my cars and have been doing so for more than a decade. No issues so far.
ZR-1 #638/1991
Old 06-29-2022   #4
HAWAIIZR-1's Avatar
I agree with you. A lot of people don?t know or trust Liqui-Moly, but that?s what I have been using in all my cars too. I?m going to try their oil for my Harley too. Top grade German engineering and science.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 06-29-2022   #5
Norwegianmopar
Norwegianmopar's Avatar
I use Royal Purple 10w-40 which also has zinc and got the approval from Marc Haibeck. JPEG_20220629_121154_5789866720562514169.jpg
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 06-29-2022   #6
Karl
Karl's Avatar
I am using Mobil 1 Formula M 5w 40 motor oil purchased from Napa. There is a QR code scanner on the label to confirm authenticity.
It is the same mineral content at the 5w 50 as tested here.
https://youtu.be/i3pNHfxKAJc
Old 06-29-2022   #7
A1990
A1990's Avatar
I run Joe Gibbs Driven hot Rod racing oil HR4 in mine. 10w-30.
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 06-29-2022   #8
Erik
Sadly, I won't be able to get it in time. The closest distributor is 8 hours drive away. But definitely will keep it in mind for future use.
Thanks!
1990 ZR-1 # 996
Old 06-29-2022   #9
Erik
Thats looking like a better option. Might be able to get this in time:
https://www.amazon.ca/Rislone-ZINC-Z...jaz10cnVl&th=1
1990 ZR-1 # 996
Old 06-29-2022   #10
Erik
Originally Posted by Norwegianmopar View Post
I use Royal Purple 10w-40 which also has zinc and got the approval from Marc Haibeck. Attachment 18070
Regular Royal Purple is available in store, but not that.
1990 ZR-1 # 996
