Old 11-10-2022   #1
pattonas
Default 1990 Passenger Power Window Switch
Does anyone have any tips on removing the passenger power window switch. Do I need to remove the door panel?
Thanks,
pattonas is offline   Reply With Quote
Old 11-11-2022   #2
BlackZR1
BlackZR1's Avatar
Default Re: 1990 Passenger Power Window Switch
Thanks,
You do not need to remove the door panel. The switch itself ?snaps? out of the door panel, then pull the 2 harness connectors out of the hole far enough to disconnect them. Remove the switch with the 2 short pigtails. I made myself a document for future reference with pictures to access and clean the contacts. If you PM me your email I would be happy to send it to you.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
