Old 08-27-2007   #1
thxalot
Default SLP Exhaust
Hi Folks,
I found this link online and was interested in putting an SLP Power-Flo exhaust on my '90. I searched the forum here and at CF, but couldn't find any mention of it.
Do any of you have any experience with it? Could one cat-back system fit the LT-1, LT-4 and LT-5?!?!
Thanks for any opinions,
-Burt
http://www.lmperformance.com/5901/24.html
thxalot is offline   Reply With Quote
Old 08-27-2007   #2
Z Factor
Z Factor's Avatar
Lightbulb Re: SLP Exhaust
I've never met anyone with that system.
http://zr1netregistry.com/forum/showthread.php?t=470
Old 08-28-2007   #3
93RubyZ
93RubyZ's Avatar
Default Re: SLP Exhaust
I've got no experience with that particular system but I once had a '97 Camaro SS and opted for the "performance exhaust" option from SLP. I'd guess they've made somechanges since then but I really loved the sound of that exhaust, it's one of the things that made that car fun to drive.
93RubyZ is offline   Reply With Quote
Old 08-28-2007   #4
Aurora40
Aurora40's Avatar
I looked into that when I was changing my exhaust. The sound clips sound excellent, and generally SLP exhausts seem to sound quite good. It also is SS and nicely priced. What was the killer for me though was that they system is not straight-through.
This may be of no concern for you though, but I really wanted a change to have the maximum performance gain possible, as that was why I was changing the exhaust in the first place. Honestly I think the stock system has an excellent sound quality. I also found the SLP tips a little, um, not to my liking.
Old 08-28-2007   #5
thxalot
Bob,
You've got a Flowmaster, right? Speaking of tips, I think those are my least favorite. I'd probably look for a pair of factory 92-95 tips to go with the setup if I get a flowmaster
Why do you say that the SLP system is not a straight through? It definitely looks like it should be.
-Burt
Old 08-28-2007   #6
Aurora40
Aurora40's Avatar
No, I actually have stock pipes. I replaced the resonator with an LT4 resonator, and replaced the mufflers with Dynomax Ultraflow mufflers and re-used the stock tips (because I think the square tips are awesome).
When I called SLP, they said the mufflers are not straight through. Meaning they have some bends, probably two U-bends. The system has no resonator, so I'd guess the mufflers may have to do a bit more muffling. The guy said their "loud mouth" mufflers are straight though, and their "power flo" ones are not and are a bit quieter.
It's not necessarily a big deal, though. Flowmaster mufflers are not straight through either, nor are the OEM ones. They may be just fine in terms of flow. I just didn't want to take the chance.
Old 08-30-2007   #7
thxalot
Bob,
I like your thinking there. The factory pipes are 2.75". Many aftermarket systems (like the flowmaster) are 2.5" diameter. Opening up the resonator and mufflers should give you even better flow characteristics than a full cat-back system like Flowmaster.
Are the LT-4 resonators better flowing than our '90 zee resonators?
Last Time I saw a Dynomax muffler it was basically a kinked straight through. Something like this:
__
__ /
They were all stainless and had a nice deep tone. Isn't that what yours look like? http://www.dynomax.com/products/ufss.asp
How does it sound? Nice deep tone, noticable in the cabin when you are leaning on it, but not detectable otherwise? Any resonant peaks as you run up the RPMs?
Thanks for the banter!
-Burt
Old 08-30-2007   #8
cuisinartvette
I have never seen the inside of the LT4 resonator but the Lt1s it really necks down inside and restrcitive...The inlet for the exhaust tip is necked down a lot, too.
Old 08-31-2007   #9
jonszr1
jonszr1's Avatar
lt-4 resonator is the least restrictive of the factory ones . doesnt neck down. . stays at 2.75 unlike all the zr1s 90 2.25 91-95 2.5hope that helps
Old 08-31-2007   #10
Aurora40
Aurora40's Avatar
Originally Posted by thxalot
Bob,
Oh hell yeah. The '90-92 resonator is the worst by far:
LT4:
Both are just straight perforated pipes inside.
__
__ /
Yes, mine are Ultraflow stainless mufflers. It's a single inlet, dual outlet. The inlet goes straight through the middle with 3" perforated pipe. Then about 3/4 of the way through the length of it, it just opens into a chamber, and then the dual tips are there. So it's actually not totally straight through, and there is no "Y". The Magnaflows had this, and I suspect they might have been a tad quieter. But the outlet spacing on the Magnaflows was too narrow to reuse the stock tips (or at least to have them look normal).
You can see the muffler here:
-Burt
The resonance is more than stock. With headers now it is a lot more. It's not as bad as the B&B car I've heard, but absolutely more than stock. It's all in the ~1500-1800 rpm range. Mostly it doesn't bother me a bit, but on long trips I wear earplugs. The sound is great. It's sort of typical of glasspacked mufflers in that it's fairly loud at idle and low throttle, but doesn't get very much louder at WOT. In fact at WOT, the mechanical engine, intake, and gear noise is still the prevalent sound in the cabin.
But I love it. It sounds great, flows great, and looks stock, which is exactly what I wanted. And to top it all off, it's cheaper than any cat-backs.
Here are some video clips:
http://vettetube.com/view_video.php?...ba18e051673d90
http://vettetube.com/view_video.php?...7ee22b6198c578
