Ok guys, i found ppl who do this job cheap for me.
What do you think in this style for ZR-1 ? is going be cool ,or ugly? ![]() I am think do this job, but i want your opinion before do it. ![]() ![]() |
I would say no.
![]() Jason |
![]() Join Date: Dec 2007
Don't do it Hadi...
Please don't do it! |
why am I not surprised.....
![]() Join Date: Dec 2003
![]() ![]() It would be blasphemy. |
![]() ![]() Join Date: Mar 2006
go for it Hadi, and while you are at it
see if you can find one of those spiffy neon under car light kits, oh, and those really big muffler's are cool too. and if it's in you're budget, one of those splash type graphic designs on the side of the car. ![]() |
![]() Join Date: May 2007
I talked to the owner of that car at Carlisle. That Lambo door kit is lame IMHO. The doors open in the normal manner (straight out and level) and then you lift the door to the tilted up position.
![]() I don't like the look on a C-4. Jim |
Hadi:
At the end of the day, it is your car, do with it as you wish. Most of us here suspect that you're a little strange, this just confirms it. Don't forget the aluminum wing bolted to the back end. If you have the doors, you must have the wing. TomC |
#10 |
![]() Join Date: Nov 2007
I often find myself swimmin' outside of the school - part of that creativeness that comes with being left-handed, perhaps? But, if you like the look, it may actually have some very practical advantages - tight parking places or when some $%^*&^ drives to the far end of the parking lot, just so he can park tightly next to the Z.
![]() A true Lambo door swings up vertically up and down from the latch - has no (or very little) lateral lean when the door is open. The door is designed from the git go to open and close that way, but not the C4 door. (So, that makes the kit a "bit" more gimmicky - not far removed from the kind of thinking a ricer uses when considering a big showy "fart-can" muffler.) Then, I'd be concerned about the quality of the kit, and "unintended consequences" resulting from some ill-fitting/poorly engineered latches or hinges, etc. Get lots of testimonials from those that have had it done. Then IF the process can be reversed w/o any residual holes or other maladies, go for it. Not my cuppa tea, but in some cars (Lambos for instance) it looks...different (but, as Z drivers, we're used to "different"! ![]() P. |
