Old 09-30-2010   #1
DaveK
Default Brake Bleeding
Hi everyone
I want to flush the brake fluid and I'm confused by the two reservoirs (car is a '91). Do they bleed seperately or does it act as one big reservoir feeding the MC? I looked in the FSM but it doesn't seem to mention which you bleed (or both). Does one cylinder service the front brakes and one the rear?
Any advice/info gratefully received.
Thanks
Dave
1991 #1516 Black/Black
davidmkelly.com
Old 09-30-2010   #2
gbrtng
gbrtng's Avatar
Default Re: Brake Bleeding
The front reservoir is for the front brakes and the rear for the rear brakes.
Suck as much old fluid as you can with a turkey baster or similar gadget.
Fill both with clean fluid, lightly cap both, and start with RR, then LR making sure the
reservoir never runs dry. Flush until you see clean fluid at both calipers - usually 10 to 15 pedal applications. Then move to the front and flush RF and then LF.
Old 09-30-2010   #3
DaveK
Thanks for the info. In the FSM it says the bleed order should be RF, RR, LR, LF - is there a reason not to do it that way?
davidmkelly.com
Old 09-30-2010   #4
gbrtng
gbrtng's Avatar
Go ahead and use the FSM sequence - I just told you the sequence I've always used.
Personal preference ...
Old 09-30-2010   #5
lbszr
lbszr's Avatar
I use the sequence your talking about, and it's been flushed about 20 times in 3 years with no problems.
Old 09-30-2010   #6
DaveK
Thanks. The front/rear aspect makes that sequence seem more sense
If using a pressure bleeder, I assume you'd pressure bleed both reservoirs? Only reason I mention this is that the pressure bleeder I have doesn't look as if it would fit on the rear due to interference with the power steering.
I have a turkey baster
Thanks
Dave
davidmkelly.com
Old 09-30-2010   #7
lbszr
lbszr's Avatar
Thanks
Dave
I pressurize each one at a time, not together. I put a fitting in a stock cap with a hose clamp to keep it from popping off, and pressurize to 8-10 psi with a differential compression tester, it works good with the small air orifice in the tool, in case the cap would pop off it doesn't cause any fluid splatter, cause it popped off once and I was afraid to see where the fluid went, but it was good.
Old 10-01-2010   #8
gbrtng
gbrtng's Avatar
It's a lot easier to enlist Wifey's assistance to mash the brake pedal. Turkey baster, a hunk of tygon tubing and a pan is all the caveman equipment I use.
Old 10-01-2010   #9
USAFPILOT
USAFPILOT's Avatar
I think you are supposed to do the RF RR LR LF in order to not mess up the ABS.
Old 10-01-2010   #10
DaveK
Thanks everyone
davidmkelly.com
