Installing another set of headers on a 94, some of you know about the little project that has expoploded on every turn.... so this is going to be nothing new.
Driver side header, does not fit again! Pictures to follow up shortly. |
Pictures...
Holy smokes... thats not even close!
![]() Join Date: Nov 2007
am i seeing this right the bolt holes dont even line up. is the flange also warped ?
![]() Join Date: Dec 2003
I guess quality control is going down the tubes,get it.
![]() Wow Jeff that sucks bro, right now i'm glad i'm not in your shoes. I'm sure SW will take care of it,i hope. Send them a gasket. Let us know how it turns out. Pete
Jeff:
Just so I'm clear, these are the same headers that this guy is selling? http://www.zr1netregistry.com/forum/...ead.php?t=5931 The same guy that says, and I quote: "THE BEST PART ABOUT THE SYSTEMS IS THAT THEY WILL ALL BE A BOLT ON ACCESSORY. FITMENT WILL BE PERFECT AND NO TRIMMING OR TWEAKING WILL BE REQUIRED. NO WELDING NOR MODDING WILL BE REQUIRED." If I'm wrong, then I'll gladly delete this post. TomC |
Thanks Jeff, I'm really worried now. I had mine coat two years ago, direct shipment from SSW to JetHot and now finally going to install. I hope I don't have these problems.
Flange is not warped, it's straight. The primary tube #1 is out of alignment, running into the steering rack..... again.
Pete, the last time I dealt with this is was 3.5 weeks until I had a replacement header in my hand. Hopefully it is less this time, as I'm tired of being hung up on cars. Especially this one. Tom, the headers in that ad are going to be the new style. I've got another car that the owner wants a set of headers as well... I don't know what to tell him. I don't want a third set of headers and go through the same crap again. Craig, I would never recommend getting anything coated before test fitting. Most dealers or manufacturers would never take a product back that has been painted or modified form the original form. I sent Jim a SSW all the picks and a run down. I'll post the update in the morning. |
#10 |
I thought that's what high-temp RTV was for?
