11-11-2016 | #1 |
'91 #473 Tuning
Gents,
Spend most of my time on CorvetteForum (don't hit me!).. Just getting old and habits are hard to break. Finally put #473 on the rollers a couple of weeks ago. With SW Headers, full SW exhaust, Hi-Flo cats, Fidanza FW, Delphi Injectors and Marc's tune, the car put down 345 rwhp and 349 rwtq. Hot engine (drove to dyno shop) and an 80 degree day. Talked to Marc and we figure we're missing about 16 hp. Past runs (before exhaust upgrades) put the AFR at 11.9. Didn't have a tailpipe sniffer this time, so not sure what it showed, but worthless anyway since I'm running metal matrix cats. Decided to do my own tuning.. Very comfortable with LS platform and HpTuners, but not OBDI. Thanks to Dominic's counsel, I now have TunerPro RT V5, Moate's APU 1 and a new AEM wideband O2 sensor to install. I suspect the Low I located a stock BIN on GearHead-EFI along with a BIN definition file to read it. With help from Dave Blundell at Moate's tech support, I finally got the current tune downloaded. I want to duplicate it on another SST 27SF512 chip so that I don't run the risk of messing up the tune that I got from Marc (will leave this chip "unmolested"). Now that I can interpret BIN files, I'll get the wideband O2 sensor installed and begin to log data so I can see how the tune sits here in Texas. Car runs great (of course! Marc's tunes are legendary), but I can't resist the temptation to tune I really enjoyed dialing in the VE tables and spark along with other tweaks on my LS2, so looking forward to learning OBDI secrets. I'll share what I learn so that others can take advantage of my wins and headaches! My ECM is a 1228331 with a broadcast code of AXFK. I'm using the stock BIN from GearHead-EFI along with the BIN definition file from GearHead-EFI. AXFK_91_Vette_5_7DOHC.bin $AF 91 Vette ZR1 LT5.xdf Both of these are on the GH site (most complete set of BIN files and BIN Definintion files I have seen on the web!) Incredible resource! My custom tune uses a $AFA Bin definition file. There are some location differences for equivalent parameters between the two BIN files, so at this point, I can't see how to use a common *.xdf to easily do comparisons, but not worried, since I'm going to create a copy of the current tune on a new SST27SF512 chip using the $AFA definition file and then create a copy of the stock BIN file using the $AFA definition file. Then can do comparisons using TunerPro RT. So, stay tuned and I'll keep everyone posted as I translate my LS tuning knowledge to the OBDI environment and TunerPro RT. Last edited by jss06c6; 11-12-2016 at 06:49 AM. |
11-11-2016 | #2 |
Re: '91 #473 Tuning
Steve,
Shouldn't be any real difference between the AXFK ($AF)calibration and the BRXB ($AFA). The main parts should be identical. GM added a couple of lines of code, but didn't change much else between the two versions of the cal. IOW, you should be able to start w the BRXB cal without worrying about "converting" the AXFK to the $AFA Mask.
11-11-2016 | #3 |
Re: '91 #473 Tuning
11-11-2016 | #4 |
Re: '91 #473 Tuning
11-11-2016 | #5 |
Re: '91 #473 Tuning
Yep, I've got it already.
Mainly interested in how the AFR looks and the VE tables.. Sent from my XT1585 using ZR-1 Net Registry mobile app |
11-13-2016 | #6 | |
Re: '91 #473 Tuning
1990 ZR1 Red/Black #2469 1990 ZR1 Black/Black #843 1993 ZR1 Ruby 40th Anniversary #112 |
11-14-2016 | #7 |
Re: '91 #473 Tuning
Mike,
Let me know when you get it planned. Just got the wideband installed. Now ready to start getting the VE tables dialed in. Steve Sent from my XT1585 using ZR-1 Net Registry mobile app |
11-16-2016 | #8 |
Re: '91 #473 Tuning
AEM Install.. all working well.. Logging data next step.
11-16-2016 | #9 |
Re: '91 #473 Tuning
I have no idea what you are doing will do! I need help just to change my oil and that's coming up. Kudos to ya Steve. I am just not mechanically inclined. Do you charge by the hour?
11-16-2016 | #10 |
Re: '91 #473 Tuning
Steve,
What r u using as a datalogger? How r u connecting to the ALDL?
