10-11-2014 | #1 |
LT5 ignition coils
I'm sure it's somewhere on the site and I should know this, but...
Is the correct coil the AC Delco D555? (4 of 'em) Same as 10467067? Is 10467067 an old PN? Any advantage/disadvantage to using an MSD or similar coil? |
10-11-2014 | #2 |
Re: LT5 ignition coils
Hi.
John here i just ordered 4 coils for my LT5 . Duralast/ignition coils from auto zone their part no. C849 @ $35.99 each. I'll pick them up after 10:00 a.m. tomorrow.You can get them from rock auto AC Delco for about $40.00. hope this helps John 1990 white/black one of a few 4L80E eq. ZR-1's |
10-12-2014 | #3 |
Is it D555 or D545? I seem to recall a discussion about these two before, but I can't find it.
The AC Delco catalog calls for D545 http://parts-catalog.acdelco.com/cat...log_search.php Check amazon - they have the D545 AC Delco coils for under $30 each with free shipping
1990 ZR-1 #2180 Red/Black Many of the usual mods for 460HP, tuned by Marc Haibeck ZR-1 Net Registry Member #1548 Last edited by ghlkal; 10-12-2014 at 06:27 PM. Reason: added AC Delco catalog spec |
10-21-2014 | #4 |
This string has been kind of left up in the air...
As stated above: Cross referencing 10467067 (the original PN) comes up with AC Delco D555 The AC Delco website says D545 when asking about the 90-95 ZR-1 There's also several coils available from lots of different sources and manufacturers, which are probably fine, but I'd like to stay w/Delco. (keeping in mind, they're probably crap today too just like everything else out there...) D545 or D555? Amazon seems to have the best price and they're both readily available. Thanks! Last edited by Mystic ZR-1; 10-21-2014 at 12:15 PM. Reason: sp... |
10-21-2014 | #5 |
I think its D555 only.
10-21-2014 | #6 |
I have used MSD coils/6A in my previous Xfire for many years. When I got my first ZR, I did the coil swap to MSD coils and wires at the time I did a porting of the top end. That was nearly 8 years ago, and I have the same MSD coils/wires in the motor today. That's my experience. I still have the OEM coils I took out, which were operational, in case anyone wants a set.
