Old 12-20-2010   #21
HIZNHRZ
Default Re: Update on my hi-miler Z project
Great news Andrew. Sounds like you're over the hump. While there will always be things to fix you'll hopefully be able to get some enjoyment out of the car; at least be able to drive it enough to be able to remember why you bought it!
Does the passenger side collector connection leak or are you just not happy with it? Hopefully someone here has what you need to tighten it up.
Old 12-20-2010   #22
VetteMed
I really just need to go to an exhaust shop, as the headers were used (off of Matt's (scholtmj) '91, and the section of pipe coming off the passenger collector was not long enough to reach the slip-fit of the Corsa pipes. So I cut some spare pipe to fit... needs some mild tweaking and welding though.
I also have some B&B tips I'm going to try to have welded on, so I'm going to have a set of Corsa tips for sale if anyone is interested.
Old 12-20-2010   #23
Did you get the Shift knob? I forgot to tell you I sent it last week.. LOL
Old 12-20-2010   #24
VetteMed
Got it, looks great, thanks :-)
Old 12-20-2010   #25
Nacho_ZR1
Originally Posted by VetteMed View Post
Finally got the car off the jackstands yesterday, got the corsa exhaust bolted up (though pretty poorly rigged on the passenger side at the header collector connection). Fired right up, and idled nicely at around 1000 rpm (indicated on tach, who knows how accurate). Lots of smoke initially, due to grease burning off of the newly installed headers, but otherwise no issues. Idled long enough to get up to operating temp, thermostat open, fan running, No check engine light (yay). Brake pedal is nonexistent, so I've got to do some more bleeding apparently.
The stock boot was very bunched up and restricting movement of the ZFDoc shortened shifter. I've got a new shifter boot and console armrest cover on the way from redline goods, will take pics after install.
We're gettin' there!
Congrats! Love the look of those seats! They look very comfy! Maybe you can take her to the dyno when she's up and running to see what kind of power she's making?
Nacho_ZR1 is offline   Reply With Quote
Old 12-20-2010   #26
VetteMed
Thanks, I like the earlier seats too, but the herniated discs in my lower back don't like getting in and out of them . These work much better for me.
I am planning on a dyno session, as long as things seem to be running well. But I want to get a few months of driving on her first, so that I feel comfortable that nothing's likely to blow up on the rollers
Old 12-20-2010   #27
... Brake pedal is nonexistent, so I've got to do some more bleeding apparently.
Use a Mighty Vac for the brake bleeding. Works great.
Old 12-20-2010   #28
VetteMed
Yaknow, I have one, and just can't ever get the process to work smoothly. Seems like it's always sucking in air past the threads of the bleeder screw.
Old 12-20-2010   #29
When I did my C5 brake upgrade, I installed the one-way bleeders. Pedal stiffened quickly when the time was right and I didn't even need any Cialis.
Old 12-20-2010   #30
VetteMed
Did you use speed bleeders, or the solo-bleed type? I tried the solo-bleed and had zero luck with them. I've used speed bleeders in the past but don't like the way the sealant on the threads is basically a one-time use.
