Old 11-19-2011   #1
vettn71
Default Seat Track
Has anyone pulled their seat transmission apart? My 16,000 mile 90's passenger seat won't move back and forth. I don't see anything jamming it, so I thought I'd disassemble and see if anything is hung up inside
jim
vettn71 is offline   Reply With Quote
Old 11-19-2011   #2
Ccmano
Default Re: Seat Track
Easy to do. Problem is getting the parts. There's a guy from Canada that periodically sells the transmission parts to rebuild it yourself for about $50 on Ebay. But he's not currently selling. I've done two now and it's not hard if you have any mechanical skills at all. There's also an outfit on Ebay currently selling the entire transmission for $150 which is not too bad. Don't make the same mistake I did an buy an old and supposedly "good" seat frame with the transmission. I got one that was broken from the get go, the other I installed and it broke in a matter of weeks. These old plastic parts inside the transmission just don't hold up.
Here's what the guts of the transmission looks like with the typical broken parts.
H
Old 11-19-2011   #3
vettn71
Great info and pictures. How did you remove the transmission from the track?
Old 11-19-2011   #4
Ccmano
The seat track separates into a right and left side when you remove the C-clips that hold the shafts in place. When you look at it, it will be obvious. Once separated the transmission can be removed.
H
Old 11-19-2011   #5
vettn71
Super! Thanks
Old 11-20-2011   #6
Pete
Pete's Avatar
I have 2 working seat tracks for sale $200 for both Left/Right came off my 1991 Z
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-20-2011   #7
vettn71
Well, I am a practictioner of the BFH mechanical maintenance method, but I don't want to bust this thing up, if I can help it. There was one C-clip on the one smaller cross-shaft and the two cotter keys. It's loose, but won't separate. What am I missing? The photo shows where I'm at.
Old 11-20-2011   #8
Ccmano
The only thing holding it together now is the motor drive shaft tubes. If you look at the motor there are two screws between the three tubes where they attach to the motor. Remove those screws and the two halves should come apart. Remove the bolts that hold the transmission to the frame, I think there are three that go through the center of the case. The transmission case is is riveted together along the outside, those need to be drilled out to separate the halves.
H
Old 11-20-2011   #9
vettn71
I did remove those two screws, but it's hanging together. I pried one of the pins that had the cotter keys in it apart. I really thought it would be much easier, which is why I'm sure there's something simple I've missed.
I appreciate the offer of the seat tracks, but my car only had 16k on it, so I'm sure it's an age thing. The passenger seat was rarely operated.
Old 11-20-2011   #10
Ccmano
It's probably just stuck at the center shaft where you removed the C-clip. Try a few taps with a mallet on the inside of the frame that the motor is attached to.
Looks like you took the transmission bolts out already. You may want to put those back in to hold the transmission firmly while you tap on the opposite frame.
H
