Old 07-10-2012   #11
Default Re: Need Advice: Miss, low rpm stumbling
Bingo on the vac pump cycling every 15 or so....that is a slight vac leak somewhere. Now discon the hose at the right water outlet tube and cap the fitting and try the key on engine off and see if the pump stops running after she pulls a vacuum. At the end going under the plenum hook up a vac tester and pull a vacuum and see what happens. Any vac leak adds more air/leans out the A/F ratio, so yes that could cause a miss.
The intermittent SES light will have set a DTC if it stayed lit long enough and the DTC will be stored as a History DTC in the CCM.
Call out to the WAZOO, as The Captain has a tech1A and that will be the best choice to see what is going on.
Okay on the filter, and the socks are proly the original ones. IDK what to say about the socks. Mine were clean after 17 yrs, but the original pumps were down on output so I changed them out. The butt-dyno could tell the difference between old OE pumps & new Bosch pumps. Just saying.....
Old 07-10-2012   #12
gunman0
gunman0's Avatar
You can see if there is a bad check valve for the secondary system by pulling the vacuum line to the middle of the driver's side of the plenum. Put your finger over it and see if the vac pump stops running every 15 seconds. If so, you can just throw another check valve there as a quick fix until the next time you pull the plenum.
I don't think a secondary vacuum leak would cause the low rpm miss like you describe. Also the fact that it picks up power over 3000 rpm seems to negate that as being a major problem.
91 Black ZR1
DRM Chip
Corsa cat-back
gunman0 is offline   Reply With Quote
Old 07-12-2012   #13
scottfab
scottfab's Avatar
Forget all effort into the secondary vacuum for now. Cycling every 15 min is not perfect but not going to be a big issue yet. When it stays on, then worry about it. Once you've found your miss then you can come back.
Yes do get a scanner. Don' t waste time with any "short two pins" and "watch the led flash" and "count the flashes".
Spend time on the 45 psi fuel issue. It may not be the source of miss but is low and will cause hard starts (long start time) and shows the pumps are tired. I would not settle for less than 50 psi. How many seconds does the engine crank before starting?
Check the codes and go from there. However, checking the MAP hose is easy and has been known to cause issues like you are describing.
Scott
Old 08-09-2012   #14
EWest
I have an update on my woes, and was looking for a few opinions. I finally got frustrated enough, combined with a lack of time to tinker recently, to take my Z to a local Corvette shop who has a guy that is familiar with the lt5 and has a good electrical guy.
At first they found a cracked spark plug at #6, which made me do a celebration dance in anticipation of it being fixed...but not so fast.
She still stumbles and sputters under load, but does not miss at idle.
He replaced the coils, the miss came back and same problem. SO he isolated the problem to cylinders 4 & 7. He thinks it is the DIS, but "thinks" is not enough for me to drop that kind of coin on a new one. He's in the process of checking all of the wiring around the coils, module, and ecm and so far everything has ohmed out ok.
Any thoughts?
EWest is offline   Reply With Quote
Old 08-09-2012   #15
scottfab
scottfab's Avatar
It would be nice to know if this same behavior is exhibited with the power key off. And what does the fuel pressure drop to when under load? I'm concerned that all the effort is going to spark.
Scott
Old 08-09-2012   #16
Any thoughts?
sounds like he's throwing parts at it. did you check the injectors? fuel pumps?
Old 08-09-2012   #17
EWest
Power key off = same behavior. I never got a chance to check the fuel pressure under load, but would that cause a problem in 2 specific cylinders, and only under 3000RPM?
Old 08-09-2012   #18
EWest
Injectors tested out fine, fuel pumps test ok, but like I said I have not had the chance to test them under load.
Old 08-09-2012   #19
4-7 are on the same coil pack. If this guy knew much about LT-5s he'd know not to suspect the DIS module.
Old 08-09-2012   #20
scottfab
scottfab's Avatar
absolutely. If you get to a low pressure situation one cyl is going to go lean before the rest. The "miss" has to start somewhere.
I assume the wires were checked out? Length on a few are the same so they can be swapped. AND if one plug was cracked I'd not rule out more damage to others. These aren't those funky Bosh plugs are they? I've seen multiple problems with those.
Scott
Tags
miss, stumble
