Old 10-27-2012   #1
crjspo23
crjspo23's Avatar
Default Speedometer issue - speed sensor code
Anybody have any experience with a speedometer problem and a code for the vehicle speed sensor?
crjspo23 is offline   Reply With Quote
Old 10-27-2012   #2
WVZR-1
Default Re: Speedometer issue - speed sensor code
Do you have a code that has been set? Your question is pretty vague!
Old 10-27-2012   #3
crjspo23
crjspo23's Avatar
Code 24
Old 10-27-2012   #4
WVZR-1
Code 24
Code 24 and NO speedometer? Have you done any under car maintenance recently? I'd check first the obvious. I'd check the connector at the VSS (L/R of transmission) and clean it also while there. No other codes just 24? Have you done a recent PROM or done anything at all that involved maybe ECM connectors?
Old 10-27-2012   #5
crjspo23
crjspo23's Avatar
Yes. We just replaced the ECM.
Old 10-27-2012   #6
WVZR-1
Check all three ECM connections, check that the PROM is seated correctly. Do you have the old ECM?
Old 10-27-2012   #7
crjspo23
crjspo23's Avatar
Yes, but the old ECM is defective. We will check the ECM and PROM connections though - thanks.
Old 10-27-2012   #8
WVZR-1
Did the car run and the speedometer work with the "defective" ECM? If yes then put it back for diagnostics should you find nothing else!
Old 10-27-2012   #9
crjspo23
crjspo23's Avatar
Car would run but badly - would not want to drive it that way. No indication of a prior speedometer problem, though.
