Old 02-19-2007   #1
jrd1990zr1
jrd1990zr1's Avatar
Default Opinions on oil
1990 ZR1, 6400 miles. Has a non original oil filter on it so the oil has been changed at least once. Not sure what type oil is now in it.
What is the best oil to use for an oil change? Filter?
Thanks for the opinions, John
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 02-19-2007   #2
1990 quasar blue
Default Re: Opinions on oil
Mobil 1 10w30 and a Bosch filter. 3401 if I remember right.
Old 02-19-2007   #3
bobbyhi
bobbyhi's Avatar
That's what I use. No problems!!!
Old 02-20-2007   #4
jrd1990zr1
jrd1990zr1's Avatar
I am not sure if the oil currently in the car is a synthetic. Is there a problem with any residual oil in the engine mixing with the Mobil 1?
Thanks guys for the advice.
Old 02-20-2007   #5
Hammer
Hammer's Avatar
Talking Re: Opinions on oil
Mobil 1 and Bosch filter here too.
Old 02-21-2007   #6
Z Factor
Z Factor's Avatar
Lightbulb Re: Opinions on oil
There is a good chance the previous owner used a synthetic as most people who own low mileage ZR-1's do not skimp on maintenance. There will be some old oil in the system since you can not get it all to drain. However if you want to be sure there is no regular oil then drain it over night, replace with synthetic then change it again within a short period of time. As to the most common oil used, Mobil 1 is at the top. Here is a poll on the filters forum members are using.
http://zr1netregistry.com/forum/show...6&page=1&pp=40
Old 02-22-2007   #7
JRD, I had the same Q when I got mine as the orig owner didn't believe in syn oil for the car. I just changed the oil & filter and let it go for the usual 3K miles/3mos and changed it again. I had no strange noises nor did anything negative occur. 14K miles later everything is still okay!
Old 02-22-2007   #8
blackjack
most synt. oil are compatible with mineral oil...you cant remove all the oil in your engine with an oil change,so my amsoil rep said you run full synthetic only on the second oil change...makes sense...
blackjack
blackjack is offline   Reply With Quote
Old 02-24-2007   #9
jrd1990zr1
jrd1990zr1's Avatar
Thanks to all for the advice.
