Old 04-06-2013   #71
tf95ZR1
tf95ZR1's Avatar
Default Re: secondarries
re thinking
Old 04-06-2013   #72
tf,
The fact is elimination of secondaries usually accompanies other mods like top end port etc. So I think Graham's graph shows that there is an appreciable increase in low end torque w just primaries activated up through 4k when you eliminate other changes. Beyond that, not sure we have enough data. Perhaps gb does.
Old 04-06-2013   #73
tf95ZR1
tf95ZR1's Avatar
Thanks xf.
But we aren't really "eliminating" the secondaries, just adding them to the primaries throughout the RPM range. So the total possible airflow (volume) at low RPM increases, but I guess Mr. Behan's point is that the airflow dynamics and characteristics change in an unfavorable manner. There must be a solution.........
Old 04-06-2013   #74
Blue Flame Restorations
eliminating the mechanical operation
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-06-2013   #75
Thx Brett.
Old 04-07-2013   #76
tf95ZR1
tf95ZR1's Avatar
Didn't somebody try electronic activation with servos? Scott F?
Old 04-07-2013   #77
Pete
Pete's Avatar
1: That can be fixed in the tune.
2: From the torque #'s this a 368ci ?
I've seen a lot of tuners programs none had any low rpm tuning.
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-07-2013   #78
Pete
Pete's Avatar
Ted the argument is if one takes secondaries completely out of the car it won't drive nice in traffic and then it's only a race car.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-07-2013   #79
Default LT5 Modifications and Driveability
Pete
My 91' ZR-1 is both.....it drives nice in traffic and is a race car (with Pete's cams and Marc's chip) and porting (plenum, IH, Heads) and Jerry's gaskets and SW off road headers/exhaust and 87 octane or 91 octane fuel and power key always on and no secondaries and Ron Davis Radiator with Marc's 180 deg thermostat engine runs cool ALL the time with TB coolant blocked off and and and.....
Defective Stant Thermostats by Marc Haibeck
And and and.....cruise control works fine in answere to the question that started this thread
Originally Posted by janozr1 View Post
Hi to all ,
Im going to eliminate secondarries with Haibeck prom - got vacuum
headache with this necessary system....everything will go out
Will cruise control - after that still be working?
Thanks fo reply.
Jano
Old 04-11-2013   #80
RHanselman
RHanselman's Avatar
Pete,
I was able to get 450 rwtq from my stock block 350. Just a little top-end porting (excluding heads) with the secondaries remaining. Wasn't really that hard
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
