Ecklers Corvette Hood Support with New Outer Sleeve
I just bought two of these Hood Supports. Shown below with Carter's Support Stop. These new Hood Supports will actually hold the hood up without the stop in place and you actually have to apply a slight down pressure to get the hood to easily and slowly start to close. Amazing what a New Hood Support actually is capable of. If I pull the hood down about 6 inches and let go it will actually go back up to full open ![]() They are about $60 if you use your own old outer sleeve...... Ecklers Corvette Hood Support Using your Old Outer Sleeve ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-16-2018 at 10:49 AM. |
![]() Join Date: Apr 2013
My supports are in good shape but the plastic locking deal is gone. So I made one out of PVC pipe that snaps on and off the support....
#3 | |
![]() Join Date: Jan 2009
Scott - I saw yours on a previous thread - and that's what I made!
#5 | |
![]() Join Date: Sep 2012
Mine do that as well. PO must have replaced them.
