From one of the people that really was a pioneer in the GM ECM tuning world, Bruce Plecan. RIP.
\ Grumpy Senior Member Join Date: Jun 2000 Location: In reality Posts: 7,554 Car: An Ol Buick Engine: Vsick Transmission: Janis Tranny Yank Converter Classifieds Rating: (0) Timing- when's enough- Final Answer OK, so you hear me harp on not running as much timing as you'd like. So when in a degree not a degree, or what does a degree really mean. If you think about it for an instant you'll see/ remember that at TDC the piston is changing direct, so it has to slow down some as it does that. Now for the none MEs (mechanical engineers) take a 6" protractor, and draw a circle. At the top of the circle we'll call that TDC. Draw a line straight up 6" to represent the rod. From 10 degrees before TDC draw a line 6" long that intersects the first line. See who the piston has moved about an 1/8" in that 10 degrees. Now repeat that at 20d, 30d, and 40d. Notice anything?. 40d and the piston is like an inch from TDC. 30d and it's 9/16" from TDC. When your running the big timing, I hope you can see now, why every degree is an important element. Then think about if your lighting the charge an inch before TDC think about how much pressure is building as the piston is trying to continue upward. Then think about how much less the pressure is rising when you light the charge just 9/16" from TDC.\ Just food for thought, Grumpy Senior Member Join Date: Jun 2000 Location: In reality Posts: 7,554 Car: An Ol Buick Engine: Vsick Transmission: Janis Tranny Yank Converter Classifieds Rating: (0) Timing- when's enough- Final Answer OK, so you hear me harp on not running as much timing as you'd like. So when in a degree not a degree, or what does a degree really mean. If you think about it for an instant you'll see/ remember that at TDC the piston is changing direct, so it has to slow down some as it does that. Now for the none MEs (mechanical engineers) take a 6" protractor, and draw a circle. At the top of the circle we'll call that TDC. Draw a line straight up 6" to represent the rod. From 10 degrees before TDC draw a line 6" long that intersects the first line. See who the piston has moved about an 1/8" in that 10 degrees. Now repeat that at 20d, 30d, and 40d. Notice anything?. 40d and the piston is like an inch from TDC. 30d and it's 9/16" from TDC. When your running the big timing, I hope you can see now, why every degree is an important element. Then think about if your lighting the charge an inch before TDC think about how much pressure is building as the piston is trying to continue upward. Then think about how much less the pressure is rising when you light the charge just 9/16" from TDC.\ Just food for thought, Grumpy
Senior Member Join Date: Jun 2000 Location: In reality Posts: 7,554 Car: An Ol Buick Engine: Vsick Transmission: Janis Tranny Yank Converter Classifieds Rating: (0) Timing- when's enough- Final Answer OK, so you hear me harp on not running as much timing as you'd like. So when in a degree not a degree, or what does a degree really mean. If you think about it for an instant you'll see/ remember that at TDC the piston is changing direct, so it has to slow down some as it does that. Now for the none MEs (mechanical engineers) take a 6" protractor, and draw a circle. At the top of the circle we'll call that TDC. Draw a line straight up 6" to represent the rod. From 10 degrees before TDC draw a line 6" long that intersects the first line. See who the piston has moved about an 1/8" in that 10 degrees. Now repeat that at 20d, 30d, and 40d. Notice anything?. 40d and the piston is like an inch from TDC. 30d and it's 9/16" from TDC. When your running the big timing, I hope you can see now, why every degree is an important element. Then think about if your lighting the charge an inch before TDC think about how much pressure is building as the piston is trying to continue upward. Then think about how much less the pressure is rising when you light the charge just 9/16" from TDC.\ Just food for thought, Grumpy Senior Member Join Date: Jun 2000 Location: In reality Posts: 7,554 Car: An Ol Buick Engine: Vsick Transmission: Janis Tranny Yank Converter Classifieds Rating: (0) Timing- when's enough- Final Answer -------------------------------------------------------------------------------- OK, so you hear me harp on not running as much timing as you'd like. So when is a degree not a degree, or what does a degree really mean. If you think about it for an instant you'll see/ remember that at TDC the piston is changing direct, so it has to slow down some as it does that. Now for the none MEs (mechanical engineers) take a 6" protractor, and draw a circle. At the top of the circle we'll call that TDC. Draw a line straight up 6" to represent the rod. From 10 degrees before TDC draw a line 6" long that intersects the first line. See where the piston has moved about an 1/8" in that 10 degrees. Now repeat that at 20d, 30d, and 40d. Notice anything?. 40d and the piston is like an inch from TDC. 30d and it's 9/16" from TDC. When your running the big timing, I hope you can see now, why every degree is an important element. Then think about if your lighting the charge an inch before TDC think about how much pressure is building as the piston is trying to continue upward. Then think about how much less the pressure is rising when you light the charge just 9/16" from TDC.\ Just food for thought, |
