Old 01-11-2014   #1
Mystic ZR-1
Mystic ZR-1's Avatar
Default Struts
Anyone know the best place (and part numbers) to get rear hatch struts and those short ones (about 6'' long) you can install on the unused "studs" for the hood?
Do the short struts make any difference when lifting the hood?
I think GM discontinued them after 88 or so, but left the "studs"
Thanks
Old 01-11-2014   #2
ScottZ95ZR1
ScottZ95ZR1's Avatar
Default Re: Struts
This post provides info for the short hood struts: http://www.zr1.net/forum/showpost.ph...37&postcount=5
ScottZ95ZR1 is offline   Reply With Quote
Old 01-11-2014   #3
efnfast
Default Re: Struts
Doug, I did the short struts on mine. Definatly makes opening the hood easier. From the upright position, you have to push it closed. Bought them from e-bay. I think I asked, and none of our regular friends (Jerry and others) had them.
Old 01-11-2014   #4
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Struts
After Gunny turned me on I added the short ones to my 94 and they sure make the hood a lot easier to handle.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-11-2014   #5
Default Re: Struts
I have a post up on this somewhere they are real cheap from rock auto.
Old 01-12-2014   #6
Default Re: Struts
Thanks
The first time I opened the hood after using the 2 small struts and the factory strut I thought the hood would fly forward and break something,too much pressure with all 3 in place,I think anyway.
Old 01-12-2014   #7
KGV
KGV's Avatar
Default Re: Struts
There is a company on ebay (PartsHighway) that sells struts made by StrongArm,. They sell the single long strut as well as the smaller struts used from 1984 to 1988. I read a post in the past where a ZR-1 owner just added one of the small struts in addition to the original longer single strut.
Two USA-Made Hood Lift Supports (Shocks/St​ruts/Arm Props/Gas Springs) 4003
One USA-Made Hood Lift Support (Shock/Str​ut/Arm Prop/Gas Spring) 4972
Two USA-Made Hatch Lift Supports (Shocks/Struts/Arm Props/Gas Springs) 4903 4904
I purchased struts from this company in the past for the trunk of my Lexus. I was glad to find parts that were made in the USA.
Ken
KGV is offline   Reply With Quote
Old 01-12-2014   #8
Default Re: Struts
Thanks
I just bought two of these Hood Supports (one for a 90' and one for a 91'). These new Hood Supports will actually hold the hood up without the stop in place and you actually have to apply a slight down pressure to get the hood to easily and slowly start to close. Amazing what a New Hood Support actually is capable of.
If I pull the hood down about 6 inches and let go it will actually go back up to full open
Hood Support Source TIPS
Old 01-12-2014   #9
Mystic ZR-1
Default Re: Struts
Thanks for all the info!
The Brotherhood is a great resource!
Doug
Old 01-12-2014   #10
John Boothby
John Boothby's Avatar
Default Re: Struts
Last year I replaced my rear hatch struts and weatherstripping. Bought the parts from the dealer for $475. I know expensive. He also installed them for me for $261. That was for struts and weatherstrip. The new struts make a world of difference!
