Old 03-25-2014   #1
Schrade
Default Max HP / TQ, with only airflow mods?
Does anyone know approximate available numbers for HP and Torque, with only airflow modifications?
To try to be clear, I'm giving a motor with 2"+ headers, 3" pipes, and max induction porting - Air Horn, TB, Plenum, IH's, and cyl head port inlets.
What #'s might be had? And what are the numbers, in millimeters, for each intake component???
And finally, WRT the memory calibration module, is more coding necessary, besides Marc's 2' delete chip?
Old 03-25-2014   #2
Default Re: Max HP / TQ, with only airflow mods?
I would only give it a guess of 500hp 450tq with a good tune. that about what I have with PnP thru heads 33mm & 63mm TB, headers and Corsa's
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 03-25-2014   #3
Schrade
500? No ****** there, Steve?
WHat are you meaning by 'PnP' thru heads'? Valvework? Plug n Play ???
Is there that much choke in the intake?
Old 03-25-2014   #4
Just a guess based on what I ended up with, PnP port and polish intake injector housing and heads, yes the valves were done. Cams retimed to 93-95 specs.
Steve
1990 Red/Red #1473
Old 03-25-2014   #5
Karl
Karl's Avatar
This is the Haibech 500 package less the lightweight flywheel.
I think a better question is the max hp without going into the cylinder heads or cams?
Old 03-25-2014   #6
Without touching the heads or cams its 400 rwhp give or take 5-10; so if you use .85 as the standard to convert that puts you in the 470-480 at the crank......
I know someone will chime in and say why the ,85 conversion is not correct because parasitic loss only takes up X amount of power....blah blah blah...
But I am going with 470-480hp
495-510 with heads........give or take 5-10....
Old 03-26-2014   #7
Locobob
Around 430rwhp with full head porting... maybe 410rwhp with just the tops of the head intake ports massaged.
Robert
Old 03-26-2014   #8
Schrade
Yeah there PR - that's another way to word what I'm askin' here; no hardware upgrading, just induction porting...
