Old 04-16-2014   #1
tpepmeie
Default power steering lines
Anybody know what size the hose fitting is on the power steering pump? I need to make a bypass loop to run the engine on the dyno & test stand.
Todd
Old 04-16-2014   #2
WVZR-1
Default Re: power steering lines
Todd
The pump end of the hose should be an M16 Saginaw fitting. You should be able to find M16 Saginaw to -6AN most everywhere. Most hydraulic stores can likely help or most speed shops also. I rethought that and I believe the pump outlet is the smaller 16MM and the inlet at the rack is the larger 18MM.
Not where I'd buy it but it will give you an idea of what I feel you should have no trouble sourcing "locally":
http://www.jegs.com/i/Aeroquip/023/FCM2608/10002/-1
