Oil leak on pass side of the block I think it may be this sensor near oil dipstick? Any idea what this sensor is? Does this typically leak oil or probable it's something else leaking? I have about 40k miles on my 90.
Thanks much! |
![]() Join Date: Mar 2007
Header stud
#3 | |
![]() Potential Oil Leaks and the OPRV Cover Plate
#4 | |
![]() Join Date: Jul 2011
thanks all, I will put it back up on the lift and take another look.. its tight up there! I cant tell exactly where it is coming from but looks like its from that switch..
Here are some pictures I snapped when it was on the lift. Does anyone happen to have the PN for that switch? I am thinking if I get this back up on the lift I might as well replace it.. I assume its an O-ring behind the switch assembly?? I am having problems finding this sensor or info about it online or with forum searches? Last edited by bans25; 05-25-2015 at 11:18 AM. Reason: Correcting pictures and information |
When I look online I find this sensor: http://www.ecklerscorvette.com/corve...1990-1995.html
Yet I believe this one is closer (however mine is all plastic): http://www.ebay.com/itm/Engine-Oil-L...96a594&vxp=mtr |
![]() Join Date: Feb 2010
Your looking for "oil pressure switch".
Gary 90-1572 ![]() |
Jerrys Gaskets can set you up
#9 | |
![]() Join Date: Dec 2003
This is the Oil Pressure Switch if that is what you need.
http://www.jerrysgaskets.com/switch-...new-90-95-9b3/ Post #4 Good Advice: Quote:
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 05-25-2015 at 02:15 PM. |
#10 | |
