Old 09-05-2015   #1
Intruder
Default Tachometer
My tachometer reads approximately 48% high based upon the AC display verification.
Intruder is offline   Reply With Quote
Old 09-05-2015   #2
WVZR-1
Default Re: Tachometer
Likely a '90 and it's not unusual and will likely continue to get worse. There's DIY repairs for recalibration and I'm sure someone will provide some links and maybe personal experiences. I understand the requirements but have never personally done a fix.
I discovered mine when actually trying to confirm a rear axle ratio that would have explained my tach variance but this was on a car that wasn't thought to be modified. I checked mine vs. a Tech1 scanner rather than the C68 display. Mine is repaired and correct but NOT by me.
Old 09-05-2015   #3
Easy way ? Take the lens off then gently pull the sweep off . Then read set it and push the sweep back on.
Old 09-05-2015   #4
Intruder
Not sure what you mean by pulling the sweep.
Old 09-05-2015   #5
Intruder
OK, I am guessing by "sweep" you are referring to the tach needle?
Old 09-05-2015   #6
http://www.zr1.net/forum/showthread....highlight=tach
Old 09-05-2015   #7
Sweep = Tach needle.
Old 09-06-2015   #8
He's kidding !!
The error is a % (of rpm) error. In short, re-positioning the needle to read accurately only works at one rpm value. the same % error will result above or below that "set" rpm.
Old 09-07-2015   #9
He's kidding !!
OR...if one were to pluck the needle and reset it to read correctly at idle, it would still read ~ 7000 x 1.48 minus 480 or 9380 rpm when actually at 7000 rpm!
One way to get higher revving LT5!
Old 09-07-2015   #10
Intruder
Yea. Who knew these LT5's would get up to 8,000 RPMs without hitting the rev limiter.
