Old 01-29-2017   #11
Top Toy
Top Toy's Avatar
Default Re: ASR issue solved
The ASR can be removed and replaced with 90-92 cables without issue. Gets rid of the clutter and you get a slight improvement in throttle response.
Sent from my XT1254 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167
Old 01-29-2017   #12
The way it's engineered, ASR has no correlation with throttle response. If anything, vacuum secondary system affects throttle response.
Old 01-29-2017   #13
Top Toy
Top Toy's Avatar
Note I said slight. Due to the direct connection from throttle pedal to the throttle cam. Just feels a little better. No change in engine response.
Old 02-01-2017   #14
Hib Halverson
Interesting about ASR. I hated it when my engine was stock. It was too intrusive. When I had the late Jim Van Dorn modify the engine to the 500-hp level, ASR's level of intrusiveness became more acceptable.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 02-02-2017   #15
I would agree. I drive w ASR On. Even experimented w ASR by leaving ON taking off from the line, then punching it to OFF once I leave the line and have traction. Crude "launch control".
Old 02-02-2017   #16
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Funny, I always did the exact same thing.
I was trying to avoid the wheel-spin in 1st and 2nd that would occur with stock tires as I hit and passed through about 5500 RPM.
Thought it might fight the tendency to get squirrelly before and after those 2 shifts.
I guess I must not drive it hard enough anymore, as I no longer am bothered by the invocation of traction control. I am usually thankful that the damn nanny actually helped!
Marty
Old 02-02-2017   #17
Marty
Yup! I quit spinning rear tires too.
Old 02-02-2017   #18
BigJohn
BigJohn's Avatar
Keep them tires turning???
Old 02-02-2017   #19
345 Pilot Supersports still break loose on a roll if I mash the pedal at 2000+rpm.
Sometimes it beats the ASR.
Old 02-03-2017   #20
BigJohn
BigJohn's Avatar
Cold tires cold pavement no stickie!!!
