Old 05-23-2017   #1
4CamJon
Default Starting issue?
Yesterday morning after a stop for breakfast, my car wouldn't start. It had power and acted like the safety switch on the clutch was not working. After multiple key cycles and locking and unlocking the doors it still would not start. We were able to get a ride home and then went back to try again. I used the spare set of keys and the car fired right up. Is it possible that I have a bad VATS key? I was also able to start the car with the primary set of keys.
Any help or suggestions would be helpful.
Thanks,
Jon
P.S. I haven't tried to start the car since I brought it home yesterday.
4CamJon is offline   Reply With Quote
Old 05-23-2017   #2
KFoster
Default Re: Starting issue?
Crank it and drive it around close to home until it is good and hot. Turn it off. See if it cranks back up. If no, let cool and try with same set of keys. If it cranks cold, remove intake and fix starter solenoid. At least that's what I'm doing now.
1990 ZR1, 1987 Mustang GT (since new), 1973 DeTomaso Pantera, 1987 928S4
Passed on: 1984 930S (gray market), 1988 Mustang Coupe Trooper car(drag)
KFoster is offline   Reply With Quote
Old 05-23-2017   #3
Thanks,
Jon
Jon that's possible but normally a security light will flash if it is a VATs issue. The primary key resister may indeed be worn. I would take a run around the hood and get the car hot with the second key then shut it off. If it does not start like before it maybe time to apply the clutch bypass mod to avoid being stranded. However it still may indeed be a solenoid issue in the starter.
Old 05-23-2017   #4
Thanks,
Jon
The ZR-1 is very easy to start in 2nd gear with a simple hand push start....just turn the key on and have a couple guys give you a hand push
Old 05-24-2017   #5
lfalzarano
Most likely you didn't keep the clutch in all the way before turning the ignition key. The VAT kicked in and disabled the starter. Wait 10-15 before properly starting your Z again. I got burned many times before I read about this is the Forum...
Old 05-24-2017   #6
when mine did this it was the clutch switch, jumpered that out and it worked ever since
Old 05-24-2017   #7
This is useful to know! Once or twice I've had my floor mat scrunch up under the clutch so it wouldn't depress far enough.
Thanks,
Old 05-31-2017   #8
Here is Marc Haibeck's article on starting issues, every new Z owner should read!
FYI, you can measure the resistance across the "pill" in your ignition key and compare it to the chart (below). From that, and your ignition key, a locksmith will be able to cut you a new key with the proper resistor chip.
Old 06-01-2017   #9
TealZR1
Exact same issue happened to me about a month ago - starter would not start from time to time and after it sat for a few hours it started up! Turned out under the plenum an oil gasket went bad sending oil into the starter which is located by the firewall. After to oil dried up it would start but ended up replacing the starter and gasket to fix the problem. Hope that helps...
TealZR1 is offline   Reply With Quote
Old 06-01-2017   #10
Speaking of "starting" issues, has anyone encountered the situation where the starter operates but the Bendix sounds as if there is a missing flywheel tooth?
It will happen once, maybe twice in succession. Let sit for a few moments and then it engages. I have also rocked the car a couple of times and the flywheel is engaged.
Comments?
