I have a 93 Anniversary Ruby Red ZR1 that had 6800 miles when damaged which I have parted out. The car has been garaged for the last 15-20 years. I?m selling the remaining parts as a single purchase. Below is a list of some of the parts: I will be listing the remaining parts in new post.
Rear Pumpkin Model 44 with 4:10 gears and Bat-wing SOLD Drive Shaft SOLD Both Half Shafts SOLD Left and Right Rear Suspension Knuckle Assembly with Spindle, Wheel Hub and Anti-lock Brake Tooth Ring with pickup Left and Right front upper and lower A-arms with spindles Hood Headlight assemblies SOLD Fire Wall Front Bumper covers (2), Impact Bar, Energy Absorber, etc. Rear Impact bar and Energy Absorber Right Rear Fender Spare Tire and Spare Tire carrier Left and Right doors, regulator assembly with motors, water deflectors, glass, etc. Left and Right Ruby Red door panels Complete carpet set Seat frames and Seat back frames Front and Rear Brake Calipers Vacuum Brake Booster (new) SOLD Clutch master and slave cylinder Rear wheelhouse liners (look new) SOLD Front and rear springs with mounting hardware Front and rear Sway Bars with mounting hardware Oil Cooler (new) SOLD Bell Housing SOLD Exhaust Manifolds with catalytic converters SOLD 16 Fuel Injectors SOLD Fuel Rails and crossover tubes SOLD Secondary linkage, diagrams, shielding and hardware SOLD Engine and Exhaust Shielding Coil Tray with 4 Coils SOLD Wiper motor and linkage Steering shaft assembly Hood release cables and release handle Rear Fender Supports (4 pieces) Under dash AC plenum assembly Frame to hood support brackets Drive line support (2) Under body X-Brace ? Aftermarket (new) Power steering pump pulley (new) SOLD Water pump pulley (new) SOLD Air pump (new) Urethane Suspension bushing set ? Total Kit (new) SOLD Hood emblem Alternator SOLD Ruby Red seat belts Brake and Clutch paddle assemblies SOLD Hood Hinges Power Antenna [B]SOLD[/B Tail light lenses SOLD Steering pump bracket SOLD Oil filter bracket SOLD PCV valves and vacuum lines SOLD Battery cables Power steering tank SOLD Roof panel front hold downs Air diffusers for dash ABS/ASR Modulator valve SOLD Radiator inlet pipe (new) SOLD Cruse control module Low tire pressure module Intake Air Horn Bolts SOLD Water Pump Bolts SOLD Fuel Injector Housing bolts SOLD Exhaust Manifold bolts with spacers SOLD Throttle Body shield and bolts SOLD Coil Tray Bolts SOLD Ignition Control Module Bolts SOLD Alternator Bracket and bolts SOLD Flywheel Bolts SOLD Coolant outlet cover bolts SOLD Transmission to bellhousing bolts SOLD Bellhousing to Engine bolts (Includes dust shield bolts) SOLD Water Pump to A/C bracket and bolts SOLD Intake Plenum Bolts SOLD Last edited by BigDave; 08-07-2020 at 01:03 PM. |
I?d be interested in fog lamps and sun visiors
PM sent
Thanks to Jerry at Jerry's Gaskets for his purchase of many of these parts. He's a good guy to work with.
![]() Join Date: Nov 2007
Im interested in the power antenna if it works with my 90...
Interested in the urethane bushing suspension kit. Is this for the entire car? Do you have a picture?
![]() Join Date: Nov 2018
Hey Big Dave, You must clear your storage in order to accept any new messages.
Thanks Mike P. |
Done.
Big Dave,Where are you located in Illinois.
#10 |
By the Peoria Airport.
