Old 07-16-2020   #101
Tripler
Tripler's Avatar
Default Re: Ruff Idle ,Huge Loss of Power
Originally Posted by Macroblock View Post
Could you record some video/audio to demonstrate the symptoms you are experiencing?
Sorry , did not have time to do it . I will try make a vid tomorrow .
Hoping tapatalk lets me upload it .
Tripler is offline   Reply With Quote
Old 07-16-2020   #102
Tripler
Tripler's Avatar
Well I knew it . I finally found the LAGFF DVD set ... Hidden in an old briefcase .
Old 07-16-2020   #103
Macroblock
Macroblock's Avatar
I'm interested in hearing the engine to determine if all 8 cylinders are firing.
Did you verify that each HI-TENSION lead is providing a signal to its matching plug?
For example, if one coil is failing, 2 cylinders will go off-line.
Did you verify that each primary injector is getting a (-) signal from the ECM? One failing or partially failing injector or (-) signal to an injector will be very noticeable at low RPMs.
Macroblock is offline   Reply With Quote
Old 07-17-2020   #104
Tripler
Tripler's Avatar
Morning . Can you tell me what tools I need to do these tests ?
Lots to learn with these beasts indeed
Thanks
Mike
Sent from my SM-A205W using Tapatalk
Old 07-17-2020   #105
Tripler
Tripler's Avatar
https://www.youtube.com/watch?v=fEXF...ature=youtu.be
When the tac reaches 2500/2700 rpm the engine surges to 3000
https://www.youtube.com/watch?v=io-9ucGfg4I
Old 07-17-2020   #106
The fans turn on when u first start the car?
Old 07-17-2020   #107
Tripler
Tripler's Avatar
No ,,, that's the garage AC running . Only thing I hear is the Vacuum pump and its very tight and only runs for a second or 2 . I found a huge leak underneath the plenum and had to mod the rubber connection with my previous plenum pull . .
Old 07-17-2020   #108
32valvZ
32valvZ's Avatar
At the risk of sounding silly, and Im not trying to be condescending, but I didnt see anywhere in the thread where you had replaced or at least ohmed out your ignition wires or checked your coils.. unless I missed it... just a suggestion..
Old 07-18-2020   #109
Tripler
Tripler's Avatar
Your not being silly sir . Pretty new to this . No I did not check the wiring and I have no experience as to how to do it . Learning as I go making lots of mistakes along the way .
Ordered more gaskets for a plenum pull . Getting pretty efficient at plenum pulls at least .
Looking into the emmisions first before another pull .
What equipment do I need to purchase to make sure the coils are working correctly .
Thanks for the input .
Lost without the help of you guys on this forum and Mr Haibeck
Old 07-18-2020   #110
Tripler
Tripler's Avatar
Just a quick list of what I have upgraded or changed so far .
New fuel filter , twice . First was full of rust so thought a second switch out would help grab any more crap.
Installed new serpentine belt
Found and fixed large vacuum leak under plenum
Installed a new IFPR
Installed new Accel Injectors
Installed new spark plugs
Car only gets High Octane non Ethanol Shell 91
That's the list so far
