Old 06-02-2008   #1
Default Video Post of Dyno Run
Thanks to Bob Stencel for the videos and great pics:
http://s134.photobucket.com/albums/q...noJetPulls.flv
92 ZR1
#234
Old 06-02-2008   #2
Default Re: Video Post of Dyno Run
Awesome, Lee!!
Old 06-02-2008   #3
Nice run
What did the barbie car dyno at ?
Old 06-02-2008   #4
Barbie vette dyno'd at 392rwhp......power to weight ratio is incredible.
92 ZR1
#234
Old 06-02-2008   #5
92 ZR1
#234
Power key was on!!!!!!!!!!!!!!
Old 06-05-2008   #6
Just talked to Randy at DRM, asked him about lean condition(I have a DRM chip), said no way it should do that even with my mods. Might be injector issues, I noted in another post I used SAP for my primaries, could have gone bad in a year I suppose.
92 ZR1
#234
Old 06-05-2008   #7
92 ZR1
#234
Lee,
Most tuners set their cals up to be on the rich side. Mine is a Marc Randolph cal and the initial pull on my motor with that calibration was in the mid 13s AFR. They'd rather foul plugs than blow pistons. 390rwhp is pretty healthy number to have an "issue". I would look at FP at WOT. Bottom line is putting scantool on it and see if it shows anything.
You did mention that you had smelled gas in the garage.
Old 06-05-2008   #8
Yes, but I had Chili for lunch, and once I opened the garage door it cleared.
No you are correct, raw gas smell from the plenum when I cracked the TB open.
92 ZR1
#234
Old 06-06-2008   #9
you used a wideband o2 right? the Dyno owners Wideband? how do you know it is accurate? might not be. I would suggest if you are going to tune yourself, the Wideband will be a good investment.
otherwise, i think the problem is the loose nut behind the wheel
Old 06-06-2008   #10
Zr1 Destroyer
Zr1 Destroyer's Avatar
Cool video......car looks mean on the dyno!!!
Zr1 Destroyer is offline   Reply With Quote
