![]() Join Date: Aug 2006
When I removed the rear wheels for cleaning I noticed tie rod end rubber boot looked squished and ripped. So, I bought a pair of polyurethane boots. Then I read somewhere that the tie rod end have a plastic swivel joint in them.
My question is, do these joints wear out? After 105,000 miles, should I consider replacing the joint rather than just the boot? ![]() |
#2 | |
![]() Join Date: Feb 2009
Rich
![]() Join Date: Dec 2003
I would expect worn rear toe rod component to exhibit the same characteristics as the front counterpart. With the tire off the ground & suspension compressed, if you can detect wheel movement in the horizontal axis, then it is time for replacement.
Thanks guys. It makes perfect sense - jack up the car and see if I can wiggle the tire.
#5 | |
![]() Join Date: Dec 2004
#6 | |
